Distibutor Problems
Old Oct 22, 2002 | 05:07 PM
bryant's Avatar
Default Distibutor Problems
Okay, I just got this car not to long ago, 3 weeks max, (93 HB Si)
It has ran fine-great since I got it, with no problems at all. But starting a few days ago, I started to get a weird squeeking noise under the hood. It was really anoying and some friends noticed it also. They suggested I tighten my belts. Hey, no biggie, I can do that.
Well I pop the hood, feel the betls for good tension, they seem fine. So for the hell of it, I start the car up and the squeeking noise comes along. But its not coming from the belts. Its kind of a squeeking and grinding noise. At first I thought it might be the tranny, but then I leaned in and the Distributor is the one makeing all the noise. I put a hand on it and its kinda shacking too.
I then shut the car off and pulled the cap off the dist. Its got brown stuff all over the place. That I have no clue what it came from. Evething looks fine in side there and nothing looks broken. The little spring that is in there, looked a little bent out of shape. So I straightend that out and put everthing back together. Started the car up and it worked with no squweek. Shut it off and went to bed.
Come the next morning I start the car up the squweek and grinding noise is back
Old Oct 22, 2002 | 05:09 PM
Big Phat R's Avatar
Default Re: Distibutor Problems (CR-X)
replace the cap and rotor
Old Oct 22, 2002 | 05:10 PM
bryant's Avatar
Default Re: Distibutor Problems (Big Phat R)
alright thanks, how much do those usualy go for?
Big Phat R's Avatar
very cheap
Old Oct 22, 2002 | 05:11 PM
bryant's Avatar
Thanks, once again
Old Oct 22, 2002 | 05:17 PM
Chiovnidca's Avatar
You probably need a new distributor. That brown stuff is some of the remnants of your dist. shaft bearing. If you take a closer look you'll probably see bits of metal all over.
Old Oct 22, 2002 | 05:37 PM
bryant's Avatar
Default Re: Distibutor Problems (Chiovnidca)
your probley, right it was when i got home from work at about 11pm. I was doing this.
Old Oct 22, 2002 | 06:02 PM
gsrvx's Avatar
New User
probably replacing the housing
Old Oct 22, 2002 | 07:32 PM
XKWISIT1's Avatar
Pull the distributor cap off and see if you have a rusty colored powder in the cap or on the rotor. If you do then that is a sign that the bearing is shot. just replace the bearing like I did
Old Oct 22, 2002 | 07:54 PM
bryant's Avatar
Default Re: Distibutor Problems (XKWISIT1)
yeah it is kinda like a brown rusty color.
Old Oct 22, 2002 | 08:11 PM
XKWISIT1's Avatar
the bearing for the distributor is shot , replace it before it siezes up. I replaced just the bearing, all it cost was $40.00 Canadian.
Ef4doorFTW
Sep 11, 2010 05:45 PM
civic91
Apr 25, 2007 01:58 PM
Hellzcivic
Honda Civic (2006 - 2015)
Nov 18, 2006 09:44 PM
