EJ6 Rear wheel Hub (bearing)
After some extensive searching, I'm getting conflicting answers. Can someone please confirm for me that the rear wheel hub from from a 1990-2001 Integra is the same as the one on an EJ6 hatch?
I'm in the process of doing a rear disc swap. I got all the parts off a 2001 Integra awhile ago and now that the weather is finally warming up, it's time to get it done. I have new calipers, pads, rotors, brake lines and e-brake cables. I just plan on using the trailing arms w/ spindles and dust shields off the Integra. I'm not even going to try to go through the headache of removing the spindles from the trailing arms. The wheel bearings that I got off the Integra aren't in the greatest shape and the ones on my hatch are fairly new so I'd like to use those if they will work, otherwise I'll just go get new rear hubs. I'd like to have all the parts ready to go before I start ripping things apart this weekend. Thanks in advance for the help.
I want to say the hubs/bearings are not the same. The hatch coming factory with DRUM brakes and the disc brakes hubs/bearings are different from the drums. I know you can use a ABS hub on a non-ABS car vise versa. Hopefully someone else will chime in
Davi_Vtec
Feb 16, 2013 08:28 AM
