ect sensor problems!! cant figure it out
Old Apr 10, 2013 | 08:08 AM
B16KENNY's Avatar
Default ect sensor problems!! cant figure it out
ok I have a 96 civic hatchback with a jdm b16 second gen...
I have a CEL code 6 which is for the ect sensor... so I went bought a new one
check engine light still on
I followed the procedure of testing the wiring for the ect sensor and its getting close to 14v to the connector... good or bad?
I kno my ecu aint bad because I had the ecu to my last 96 civic coupe with the same engine...
I know theres a coolant switch but my fans work so its good
I know theres a coolant sender but my temp gauge works so its good...
I dunno what else it could be... any help would be great...
Old Apr 10, 2013 | 08:17 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: ect sensor problems!! cant figure it out
It's supposed to be 5V, can you take a pic if the connector and what's the wiring colors going to it?
Old Apr 10, 2013 | 08:46 AM
B16KENNY's Avatar
its a 2 pin connector and the wire colors are blue/black and black... I can take a pic of it later im at work right now...
Old Apr 10, 2013 | 12:09 PM
B16KENNY's Avatar
anybody? I seen other posts but they all talkin bout the ect switch I need help with the ect sensor
Old Apr 10, 2013 | 02:09 PM
accorse07's Avatar
There is a switch, sensor and sending unit. Switch and sensor are both 2 wire while the sending is 1 wire. Which one did you not replace/troubleshoot?
Old Apr 10, 2013 | 02:15 PM
redyute's Avatar
If you are getting 14v and you are testing the correct wire, then your sensor is not your problem.You might wanna try an other known working ecu.
Old Apr 10, 2013 | 05:14 PM
fcm's Avatar
fcm
Old Fart
Are you using the USDM engine harness from the 96 Civic or something else?
According to my wiring diagrams the wire colors for the ECT sensor are red/white from ECT at ECU/ECM/PCM, and green/black from junction connector and ECU/ECM/PCM.
The ECT sending unit is a yellow/green.
The ECT switch is a black and a green.
Again according to my wiring diagrams, but then it is just a Haynes manual. 94
Old Apr 10, 2013 | 11:28 PM
holmesnmanny's Avatar
Odds are he's testing the wrong sensor. OP, you should be testing the two prong connector under the distributor. There is another sensor that is one prong. Leave that one alone. Test the other one next to it.
Old Apr 11, 2013 | 04:12 AM
B16KENNY's Avatar
Im testing the right one... I no theres 3 different ones I said that at the beginning...
there good my fans come on and my temp gauge works... n im pretty sure the switch and the sender wont turn on the cel light...
the engine harness that's under the hood is all jacked up the wires coming from the coolant sensor connector is blue/black and black.... n they cut the wires and added speaker wire to make the wires longer... and the coolant sensor itself is new... its stupid...
but whatever I just wanna get this check engine light out..
and im testing the two wire connector under the dizzy...
Old Apr 11, 2013 | 05:32 AM
fcm's Avatar
fcm
Old Fart
Not exactly what asked, what I asked was, "Are you using the USDM engine harness from the 96 Civic or something else?"
If the engine harness is not from a 96 USDM Civic, wire colors may be differant and finding the problems or tests to suggest will be impossible, more so if the harness is "all jacked up".
We want to help you get it fixed as much as you want it fixed, but we need to khow what we are working with.
What color are the ECT sensor leads at the other end of the speaker wire. 94
Old Apr 11, 2013 | 08:34 AM
B16KENNY's Avatar
ok well its not the colors you said so my guess is its another harness... the colors are blue/black and black, and at the other end of them speaker wires its the same colors... blue/black and black..
I have some instructions from AllDataPro and it says the white/red wire ur talkin bout but its making it hard cuz the wires on my ect sensor connector are different...
I was thinking just take the engine harness out and follow the wire n see if its corroded/damaged somewhere...
Old Apr 12, 2013 | 03:52 AM
the coolant temperature sensor only receives reference voltage so if you're getting battery voltage you must be testing the wrong connector
Old Apr 12, 2013 | 04:26 AM
B16KENNY's Avatar
I just took the whole harness out n rewired it... its good now...
Old Apr 18, 2013 | 10:02 AM
B16KENNY's Avatar
ok code 6 came back on..... I took out the wire harness and replaced the wire I got a new ect sensor and a new radiator fan sensor... the fan comes on the ecu is good n the ect sensor is good... I have no idea what else to try.. any ideas??
Old Apr 18, 2013 | 10:32 AM
Technical Hero
Trace the wire from the sensor back to the ecu for continuity. Post pics of the sensor wires and connector.
Old Apr 18, 2013 | 11:34 AM
B16KENNY's Avatar
ok I will post pics soon
traxxasx
May 27, 2015 01:50 AM
DO-WORK-SON
Transmission & Drivetrain
Apr 17, 2013 07:37 AM
ONEFASTJDM
Jul 16, 2009 10:37 PM
prelude-bb3
Jul 25, 2004 11:42 PM
Nerv2g
Jul 29, 2003 08:19 AM
