92 eg build. slight build beast7, building 4th gen dohc zc
joined a while ago, had the car for a while. now starting my build thread.
got the car with the b7, i did a bit of work on that, and then picked up a 4th gen dohc zc from a friend for $50, and i am in the middle of building it for boost to drop it in my eg.
heres the car the first day i picked it up after 5 coats of polish and 2 coats of wax
cleaned the steelies
painted them black
steelies on the car
changed out the deck from my old car to this car
after the first month of driving this car, with the money in gas i saved i bought this alphawerks 4-1 stainless steel header $100
painted them black
steelies on the car
bay how i got the car, after i installed the header
rotors were warped really bad, so i picked up hawk pads, powerslot rotors, russel braided brake lines, and stock rebuilt calipers. $220
then i started having clutch issues. bad clutch MC, replacement was faulty, and clutch was chattering in first gear during downshift/engagement. bought quality made in japan slave and mc, tru lite 7lb $140 aluminum flywheel, and centerforce dual friction clutch $300 and braided clutch line $25
did a tune up, iridium plugs and msd wires. painted intake tube black. wires and plugs for free lol
cheapy rear upper strut bar $35
picked up some piaa 4000k bulbs for free lol
took the side mouldings off
found a generic one piece thick billet aluminum rear lower tie bar for $25
picked up an a6 cam for $50
map sensor nipple on the throttle body broke, so here was my temporary solution to fix it. tb spacer from a friend for free lol
until i bought this 60mm b series tb
also a buddy gave me a 70mm bbk tb for free
bought a vac gauge $28
picked up a longer intake tube with the throttle body and k and n air filter for $140, sold the k and n for $35 and old intake tube and filter for $100, bought the vibrant filter for $19
polished the intake tube
picked up a y8 tranny clutch, flywheel, starter, slave for 160. sold clutch/flywheel for $60 and my old tranny and clutch/flywheel for $150
slightly tinted the tail lights
pw jdm 540g brass shift **** $70
picked up some dc teg seats front and rear $150
old vs new
old vs new
well then my hg blew..
felpro mls $80 ..****..
hondata intake manifold gasket $60
yonaka dual core aluminum rad, $150 new
saw this, and had to match that up..
picked up a z6 intake mani
cleaned it up
arp studs $125
4L of redline 10 30 adn k and n filter $60
resonated test pipe $75
port matched intake runners
and manifold
and header
arp studs $125
and manifold
and header
and plenum
skunk2 billet aluminum adj cam gear $140
exhaust runners sure opened up a lot
and then i polished them up a little
started assembling
then i had a vac leak from the manifold, wasnt completley torqued down on the middle nut on the bottom, snugged it up, and then corner one felt loose, so i snugged it up and went a little too tight, and it cracked
started assembling
can slightly see it in the coolent passage
friends step dad has it at the moment to weld it, its been quiet a while since i gave it too him. hope to get it back soon before i get this thing tuned before i drop the zc in as its running so rich it smokes grey/black.
then after all that, my buddy calls me and says $50 and alll the other miscalanious **** in his garage is mine or its going to the scrapper. SWEET! 4th gen DOHC ZC, spare dx trans, axels, wiring harness, flywheel, and zc manifold. sold the spare trans for $150
shampooing it down
he was running used chevron 15 40 dumb truck oil
my plans for the zc is to rebuild with forged internals, port/polish, bored cylinders by .5mm, mill head, run high comp z6 pistons, static 9.8ish :1 CR, and eventually down the road boost it.
started dismanteling
shampooing it down
temp sensor wires broke clean off when loosening it from the head
cleaned up the runners on the manifold a bit
pulled the oil pan
crank pulley cracked and broke when pulling it off
cant believe he ran this timing belt
pulled the valves
pulled the oil pan
pulled the valves
nice and dirty
started porting
did a compression test on the b7. ranged from 208-228
the last picture file on pb got corrupted
went to my friends to find the dizzy...found it in a bucket full of water that had froze..great..
started porting
picked these rods up from a guy from a local forum, new for $250
had a few nice days, decided to do a quick wash and wax on the car
got some older aem tru time B series cam gears from a buddy for $50
valve guides are worn, some valves were clean
others not so much
although, all the intake valves were nice and clean
ex. cam
in. cam
others not so much
ex. cam
in. cam
pulled the vc to check the torque on the headstuds, nice to see the valve train is still nice and clean
polished the combustion chambers
Nice build so far. One thing I would recommend if there is one of that engine is a timing belt cover. Don't want a rock getting logged in there and putting all that money to waste.
i have the bottom timing cover, it didn't come with the top most timing cover that covers the cam gears, but i dont think a rock will get lodged up there
