Can someone tell me what these wire are? obd1 & obd2 gsr
This is a 95 gsr with a converted obd2 engine harness (I swapped over the inj,dist,alt plugs)
This is the only plug left.
The car side has 2 wires red & yel/blk ( evap purge solenoid I think)
The obd2 engine harness has 3 wires wht/red blue/red red/yel (evap purge solenoid I think)
Can someone tell me what these wires are for sure? And/or how to hook them up?
That plug with three wires on the OBD2 engine harness is for the CKF and the signal wire for the EVAP purge solenoid.
The wht/red and blu/red wires are for the CKF and the red wire is for the EVAP purge solenoid.
If you are OBD1 you can forget about that plug. If you want to wire up the purge solenoid that is fine but it will have no affect on performance.
If you have any questions just ask.
-kenji
-kenji
Alex Preece
Oct 24, 2018 10:31 PM
