98-B18C in 96 dx exhaust question
I've checked for over 4 hours now and I know i've seen the answer before. I have a 98 B18C all original with the original header and catalitic converter installed in a 96 civic Dx. I want to install a exhaust pipe and muffler from the cat. back without doing modifications. What exhaust pipes should I purchase? One off a 99-00 si or 98 Integra exhaust since it would be the same size.
Answers would be appriciated or just copy me the thread.
Thanks to all
Thanks to all
Depending on the length of the original gsr cat and manifold, you may still need to modify the midpipe length. Don't know for sure the actually lengths, but 90-01 integra's do have different length manifolds and cats, which is year and model dependant.
See this is what I was talking about.
I would assume if you use the shorter one that the cat for it would be longer to compensate for the shorter manifold. Vise versa for the longer version. Im going to do a lil more digging on this because I want to run a gsr manifold or 95 itr 4-2-1 manifold on my b16b.
Thanks, I have a 98 B18c JDM motor with the original manifold with orginal catalytic converter. I would like to go from the cat back if possible because of the 2 oxy. sensors located in the cat. converter. Good info
fake mugen power
Dec 14, 2003 04:55 AM
TONEBONE
Aug 4, 2002 08:38 PM
