Fuel economy thoughts.... :)
Old Apr 8, 2013 | 11:41 PM
ludelover86's Avatar
Icon4 Fuel economy thoughts.... :)
Morning does anyone think this might be a good idea?
Removal of the air con pump, and getting a shorter belt just to run the alternator? Having slightly less drag on the engine making it easier for it to run with less ancillaries?
Old Apr 9, 2013 | 02:20 AM
pentaq's Avatar
Default Re: Fuel economy thoughts.... :)
If you're not using AC, the pump has a clutch which makes almost zero drag on engine. You can gain 0,001 mpg because of removed weight.
Old Apr 9, 2013 | 03:26 AM
Slambeard's Avatar
How about a longer geared tranny..?
Ah I see, not enough to compromise taking out in that case then
Old Apr 9, 2013 | 03:28 AM
^^ what other trannys would fit? I've got the F22B dohc engine, n the gearing isn't all that great, sat at 60mph in 5th gear it's at 3000 rpm
Old Apr 9, 2013 | 03:35 AM
Slambeard's Avatar
I'm not to familiar with the F-series engine series.. But I wonder if they make a B-series tranny conversion kit. Just some food for throught. I'll do a little research on this..
Old Apr 9, 2013 | 03:36 AM
Slambeard's Avatar
Best thing would be a proper tune up and make sure your car is running in great shape.
Old Apr 9, 2013 | 03:49 AM
fair play, I'll try and find some info too, n yeah it does generally run like a dream until recently and a few components failed on me, power steering pump, harmonic balancer/crank pulley, exhaust. got a brilliant service history but has covered a few miles now, about 196000 kilometres so :/ but still pulls really well, should have the rest of the parts this weekend and have it back on the road again
Old Apr 9, 2013 | 03:52 AM
Slambeard's Avatar
That's what I like to hear. If you "could" do the B-series tranny swap, a longer geared tranny should improve your MPG.
Old Apr 9, 2013 | 03:53 AM
Old Apr 9, 2013 | 03:56 AM
Yeah that would be ideal, I dont have a clue about these ratios on the post I just posted, its all just numbers to me lol, but longer ratios definitely makes sense to improve fuel economy going to have to spend a bit of time looking for a way to do it, or find out if its possible
Old Apr 9, 2013 | 03:58 AM
Slambeard's Avatar
Would defiently help! May be worth looking into!
Old Apr 9, 2013 | 04:00 AM
Yeah for sure, my gearbox is the M2J5 so whatever the ratios mean on that table... gonna have to get on looking into it
Old Apr 9, 2013 | 04:05 AM
Slambeard's Avatar
JDM Si tranny? Well that's a "performance" tranny. You could downgrade to a longer geared tranny but I would just keep your Si tranny. What kind of MPG are you currently getting?
Old Apr 9, 2013 | 04:11 AM
Slambeard's Avatar
I see companies make a H2B adapter plate which lets a H/F series engine be mated to a B series engine. So researching this plus looking into a longer geared tranny would accomplish what your wanting! See if this H2B adapter plate will work for your Prelude. A little researching goes a long way.
Old Apr 9, 2013 | 04:13 AM
Yeah, jap import like, and is it the performance tranny? even more I didn't know about the car lol... and not brilliant, maybe 20 round town, and not much more than 30 at a push on a good run down the motorway sitting at 70-80 mph, the exhaust has been blowing for a while though, so weather getting that replaced will help or not I'm not sure, doesn't sound nice blowing either way tho
Old Apr 9, 2013 | 04:17 AM
Slambeard's Avatar
True. Well an Si is above a base model. Looking at that chart it does look like their might be a couple trims above this Si though.
https://honda-tech.com/forums/hybrid-engine-swaps-18/h2b-no-adapter-plate-kit-qs-2828357/ this seems quite interesting, seems like its able to be done so.. but then if its a good box I've got, its all decisions with cars, fuel economy or performance lol.. never get both in one car
Old Apr 9, 2013 | 04:20 AM
Slambeard's Avatar
Never get both! Pick and choose!
Old Apr 12, 2013 | 07:28 AM
BlackLude90's Avatar
Correct me if I'm wrong. I'm pretty sure F series transmissions bolt up to H series engines? If so, my Accords transmission would bolt up to the Prelude engine. I like the gear ratios on it. Cruising at 60 RPMS are I believe under 2500.
Old Apr 12, 2013 | 07:38 AM
schmitty915's Avatar
I would do a tune up and make sure all systems are functioning properly.
I get 27-28 combined city/highway, spirited driving, VTEC, etc. with an M2F4 transmission and no EGR.
But if you want 30-40 mpg, get a civic to DD.
Old Apr 12, 2013 | 07:44 AM
M2J5 is not a performance transmission. Look at those gear ratios.
johnnyb588
May 31, 2014 09:16 PM
romeo_f
Mar 1, 2011 06:48 AM
Vagitarian
Dec 26, 2009 02:34 PM
hms.mclovin
Sep 30, 2009 07:00 PM
speedfrk69
Apr 13, 2004 03:50 PM
