s300 help, high iddle, ses, safe mode
Old Apr 8, 2013 | 08:54 PM
wingzero90's Avatar
Default s300 help, high iddle, ses, safe mode
Need help turned my car on the other and the check engine light is on simple fix i tought.
I have hondata s300 installed with basic gsr stock tune with certsine things turned off or slightly changed. I have a b18c1. The problem is that it has a high iddle 2000 rpm, and safe mode is on unable to go.over 4000 rpms. When ihooked up my laptop too see what the code was i was unable to comunicate with the ecu. So i eent to hondata site followed the steps and it states to fix the dtcs before continuing.
So my main question is Is it safe to use the flash codes with the s300 installed or not?
Old Apr 8, 2013 | 08:55 PM
wingzero90's Avatar
Default Re: s300 help, high iddle, ses, safe mode
Before any one states it i did try researching but was not able to come up with a clear awnser
I wanted actual ecperience of anybody doing it
Old Apr 9, 2013 | 06:26 AM
Turbogixxer's Avatar
Sounds like your ECU is bad and/or a bad soldering job on the ECU. It is rare, but can happen that the S300 got fired. That is mostly the users fault.
See if you can get a good working s300 ECU to put in the car.
94GSRMR
Aug 27, 2010 02:32 PM
kardal86
May 24, 2010 08:59 PM
turbohatch322
11
Dec 5, 2009 10:56 AM
turbo sol
Apr 13, 2009 10:14 PM
