CEL'S - b16a2 in 95 eg coupe
Ok so i pulled my b16a2 swap a few days ago to remove the power steering and a/c lines that have just been sitting in the car since i bought it and so that way i could properly paint the engine bay. Well after a long day's work of pulling it out , painting , and putting it back in the car, she decided she wanted to give me issue's and throw a couple of Check Engine Light's on me. the 2 CEL's it threw were - CEL #6 ECT - water temperature sensor and also #21 VTEC spool solenoid valve. I decided a good first place to check would obviously be where to 2 sensors are on the front of the block and head. So i looked and both of them and seemed to be worn at the connection points where they ran into the sensor itself. One actually broke off so i de-pinned it and redid the wire the way it was and put it back into it's corresponding hole. Since i was in the area and they were all looking rough i decided to redo all 4 of them and make sure they were back to new. Both sensors are fully plugged in with both pins correctly put into them. But the car is still throwing the same 2 code's. The car did not have any CEL's before the motor was pulled and put back in. Needless to say this has been a big headache the past few days and has been driving me nutts cause i can not stand seeing that damn yellow light on my dash and i can't seem to find the issue here. So if anybody has any clue's or ideas or even advice for troubleshooting these 2 issue's that would be awesome. Thanks in advance !
CEL is not a instant CEL. When you turn the key to the fully on posistion it takes about 4-5 seconds of it being fully forward for the CEL to then trip and show up on the dash
Got rid of CEL #6 and CEL #21 but car is now throwing CEL #22 VTEC pressure valve . This is my only CEL and i am currently puzzled as to how to fix it or what the real problem actually is. PLEASE HELP
well just went outside and switched them around and reset the ecu and disconnected teh battery and we are still at the same point i was before this. So unfortunatly this did not solve my problem. Any other suggestions?
So i was able to get rid of the CEL #6 water temperature sensor by depinning the sensor and putting the wires in the sensor on the block directly. the connector itself is bad. it looks slightly melted. So i will need a new connector for the sensor on the block. bad i realized after redoing that wiring i left the single wire connector that goes on the top of the VTEC solenoid off which caused it throw CEL #21 VTEC spool solenoid valve. Now after i put the connector back on the solenoid the car is now throwing CEL #22 VTEC pressure valve . So i am still puzzled as what the hell the problem is. Any help would be greatly appritiated !
justinCO
Southwest (Sales)
Sep 8, 2007 08:10 AM
