P0136 Problem And GSR Question
Will a P72-A04 USDM ECU work with a 96 JDM GSR swap in a 99 EK hatch with a Jumper harness for OBD2b to OBD2a without any problems or CELs because i'm trying to pass NYS inspection????? Plus i'm current using a P2T Em1 Ecu so i can pass but i'm getting a P0136 Secondary O2 sensor code i replaced it the sensor and i still get the code and i rewired the wire to the sensor so there no connection problems what can be my problem????? ALL help is Appreciated
•Faulty O2 sensor leak in exhaust close to O2 sensor
•Short to voltage on O2 signal circuit. incorrect wiring.
•Open in circuit resistance caused by corrosion in connector
Your only fixes are replacing the o2 which you already have.
Repair short or wiring issue.
Clean and repair any connections/grounds.
From what I have gathered from your last thread I'm gonna put my money on the bold.
And seeing how you have already replaced your sensor I'm going to assume it is not stuck or functioning improperly, So exhaust leak and wiring is going to end up being where your problem resides.
Also low voltage can mean it's running rich or lean vise versa. Are you consuming more gasoline then it should. Do you smell a rich fuel mixture while driving etc. Cause a problem causing a rich/lean condition can be the root issue of why that sensor shoots that code.
Not the sensor itself.
deftones0817
30
Sep 2, 2006 05:21 PM
