Making power with my turbo manfiold
Old Apr 7, 2013 | 04:00 PM
seelback's Avatar
Default Making power with my turbo manfiold
Well got bored and decided to do something different. I put my custom turbo manifold on, made a up pipe coming from the t4 flange to the existing hole in the hood where my turbo up pipe is suppose to go. swithced from osidetiger 660cc injectors to id2000's(getting ready for turbo) and put on a moroso kicked out 5.5qt pan, and switched to brad penn oil
heres the specs on my setup when i made 197whp, the only thing different now with my setup is what i stated above.
b20z stock bottom end 100,000+miles
b16 head stock ports
97-99 spec itr cams
jun springs and retainers
skunk2 pro cam gears and composite fuel rail
itr i.m. and itr tb bored out to 65mm, p2r tb gasket, hondata i.m. gasket
ctr crank pulley
itr 4-1 header, 2.5" exhaust, magnaflow resonator, vibrant muffler
b16 tranny, itr lsd, fidanza flywheel, clutchmasters clutch, omni power master cylinder, b&m sphearical shifter, mfactory shifter bushings
hondata s300 and hondata coil pack retrofit
tuned on e85 by V-SPEC1
car is a ek hatch full interior, full-race traction bar, skunk2 V1 proS suspension, bwr lca's, asr rear subframe brace, buddy club rear camber kit, front ex sway bar, moog upper front adjustable ball joints, blox front lower extended ball joints, energy suspension bushing kit
this is the fastest pass @197whp with the setup listed above minus a/c and seats, ive trapped 105mph before
heres pics of the manifold
with turbo on
this is what it made yesterday with the turbo manifold N/A
heres the vids
Thank You V-Spec 1 for doing a awesome job with the tuning. I will be going to the track this tuesday to se how she does. I will keep you guys updated!
Old Apr 7, 2013 | 05:14 PM
V-SPEC 1's Avatar
Default Re: Making power with my turbo manfiold
Couldn't believe we made more power using that turbo manifold I sold to you lol. It's awesome watching those flames come out of the up pipe right after each pull. You are welcome buddy anytime.
Old Apr 7, 2013 | 07:50 PM
FlewByU352's Avatar
I always wanted to see what would happen if I ran my Full Race ramhorn manifold all motor with a down pipe attached where the turbo flange is.
Old Apr 8, 2013 | 02:36 AM
seelback's Avatar
Try it and se what happens, just make sure the wastegate is on or something else blocking the the wastegate hole on the manifold.
Old Apr 8, 2013 | 08:19 AM
98vtec's Avatar
moderator emeritus
wow, talk about something different!
what are the specs on this manifold?
Old Apr 8, 2013 | 08:48 AM
seelback's Avatar
what specs are you looking for? im not a header guru guy like some of the people on here. i will try to find a pic of the manifold off the car.
Old Apr 8, 2013 | 08:52 AM
98vtec's Avatar
moderator emeritus
OD of tubing
Overall length
any steps?
do you have a graph with the ITR header setup?
Old Apr 8, 2013 | 09:06 AM
seelback's Avatar
OD of tubing
Overall length
any steps?
if i have time to pull manifold off i will give you specs. what do you steps? i tried finding my 197hp graph last nite but couldnt find it. i will try to find it again, i know i have it somewhere if not i will get it off of the dyno's computer.
Old Apr 8, 2013 | 09:14 AM
98vtec's Avatar
moderator emeritus
it would be a cool comparison for sure. steps meaning changes in OD of the piping and at what length they change.
who made this turbo manifold?
Old Apr 8, 2013 | 02:15 PM
V-SPEC 1's Avatar
We don't know who made the manifold, we wish we did.
Old Apr 9, 2013 | 01:46 AM
seelback's Avatar
I will pull manifold off this week and give better pics and specs you were asking for. But i dont think the runners are equal length.
PR8urVtec
Jul 13, 2016 09:15 AM
hellakapps
Feb 12, 2008 04:29 PM
adqnnlude
Jul 16, 2006 11:56 AM
