causes of hot cylinders or extremely lean condtions?
wat if you knew that you were getting the right amount of fuel.....?
[Modified by dirtySOHC's, 12:25 AM 10/23/2002]
Answer: not enough fuel
Hot cylinders can be caused by:
1) malfunctioning cooling system
2) malfunctioning oil system
3) too high compression and not enough fuel
4) overbored motor with excessively thin cylinder walls
5) overboosting in F/I
Extremely lean conditions can be caused by:
1) not enough fuel i.e.
i) bad fuel pump
ii) bad injectors
iii) ecu problems
iv) kinked fuel line
2) too high air:fuel ratio i.e. bad ecu, bad 02 sensor, too much boost etc.
i) bad fuel pump
ii) bad injectors
iii) ecu problems
see we are getting somewhere. thanks
would a blown headgasket be a cause or piston damage?
where is everyone else on this
maybe that was a bad example.
warped head? cracked? could that create high temps?
[Modified by dirtySOHC's, 1:56 AM 10/23/2002]
basically wat all my plugs look like
my compression sits at 160 160 165 170 since a blown headgasket would kill my comp then that cant be the cause. and a warped or cracked head is not it then......it would have to be my cooling and fuel system.
[Modified by dirtySOHC's, 2:34 AM 10/23/2002]
Guest
Posts: n/a
Anyways, blown headgaskets can be caused by a faulty cooling system, but by the looks of your plug, you've got some fuel/timing issues there.
they are 5's....maybe i should switch to 6's. my timing is at 2 degree's retard and i have checked cam timing and everything lines up.
this motor has given me so much bad luck......i need to hurry up and save harder so i can chuck this one out the window.
Guest
Posts: n/a
