turbo, rods, pistons, FOR SALE
Srp pistons my current bore on my block is too big for these pistons. I have to sell these and buy other ones. They are brand new never used. One piston was opened from packaging at machine shop to size up with my block. Everything else is unopened. My loss is your gain, grab these up for less $$$$.
Standard Feature:Dome and dishes feature smooth flowing radii for excellent flame travel. Thick ring lands for nitrous oxide/forced induction use on low compression pistons. Valve pockets machined to accept oversized valves.
Engine:ACURA 1994-01 INTEGRA GSR B18C1
Bore:81.5mm (0.5)
Stroke:87.2mm
Rod:138mm
Compression Height:30mm
Head Combustion Chamber:41.5cc
Crown Volume:1.4mm
Weight (Grams):281g
Compression Ratio:10.5:1 (C/R with .040)
b16 crank $120 standard spec about 120k. perfect looking journals. came from running engine with no problems. my idiot friend over torqued the head and stripped out the block. just decided to part out block so i have pistons, rods, etc too!
garret turbo journal bearing . shaft play not within spec $125
turbonetics bb turbo 57 trim $400
ls eagle h beam rods brand new never used $300
text only, no calls
five oh three-567-6456
turbo civic gsr b18c b16 1.8 parts
Bore:81.5mm (0.5)
Stroke:87.2mm
Rod:138mm
Crown Volume:1.4mm
Weight (Grams):281g
text only, no calls
