engine cradle
Old Apr 4, 2013 | 08:27 PM
skill178's Avatar
Default engine cradle
Bent the mount location where my lower lca bolts in, local shop said I can just replace this as it is the engine cradle,
Any one know anything about changing them or. Compatiblity between cars?
91 civic si
Old Apr 4, 2013 | 08:35 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: engine cradle
it's called the rear crossmember and you can use one from the 88-91 civic CRX. i am not sure if the one from the RT4WD version is compatible.
Old Apr 4, 2013 | 08:37 PM
Perkul8r's Avatar
the engine actually mounts in two spots on the chassis. And than has two mounts on the front and rear cross member. You can easily drop the cross member without dropping the motor.
I believe any 88-91 crx or hatch cross member will work. I am unsure on the 4 doors. But they should work too.
Old Apr 4, 2013 | 09:48 PM
skill178's Avatar
Thanks, I'm pretty familiar with these cars and all but I've never delt with the frame or cross members, not much bolts to it does there? Looks like the lca's and rear mount
looks to be fairly easy but can anyone clarify the part interchangeability?
local junk yard said a CRX HF wont fit but everything else will, that makes sense because I know the HF had a few different things on it between the si and dx,
can anyone confirm the CRX or any of the 3 body civics fit my 91 hatchback SI?
also does AT or MT change anything?
sfreeways
Nov 15, 2015 12:27 PM
Crx_b16
Mar 4, 2009 04:53 PM
5genhatch
Feb 18, 2008 10:20 AM
haroldthefly91crx
Apr 27, 2006 07:16 PM
miller
May 11, 2004 02:35 PM
