rear mount replacement
is it possible to replace this rear mount without having to pull the motor?. what type of tool setups are you using. oh its a 93 hatch with a b18
Re: rear mount replacement (5genhatch)
yeah u can replace the rear mount without pulling the motor. what i did was , i placed two jacks under tranny and oil pan, removed the long bolt and l pivoted the engine a bit and i also removed T bracket. and removed 3 bolts that hold the rear mount. and installation is the reverse of removal. it is time consuming, but it can be done.
Resident Gearhead
Is possible, but not fun. I did it when I replaced the mounts with HASport units. Loosen the bolts on the other two mounts so you can move the engine around to free up some room. Removing the lower torque mounts will probably give you more free play as well.
Good luck
Mc
EDIT what crazy said sounds better.
Good luck
Mc
1SlowSi
11-01-2008 05:42 AM
