changing head bolts
im ready to set my head on and i was wondering if it is nessary to chance the head bolts or just use the ones from before, parts are
mugen head gasket
skunk 2 stage 2 cams
skunk 2 springs and retainers
mugen head gasket
Question is, do you feel like pulling everything apart and replacing the HG if you reuse boltsand there is a problem?
If not, just buy new stuff. If you have the time, money, and enegry, then go for it as is.
I also reuse oem headbolts only if its the first time for reuse,
I usually judge the bolts:if they show discoloration once out,or the head of the bolt has a/or shiny corners no matter how small before I remove them I will not reuse, done this on a number of engines with no problems.
My preference is arps over oem when I can get a good deal on a set of used ones.
From: Pensacola, FL and every Court House in Louisiana
Never reuse headbolts.
Also, make sure you torque them in the correct torque sequence according to specs. Is your head and block both level as well? Might wanna get them checked out to be sure.
That is some pretty impressive hardware to not use anything less than head studs. Nearly all manufacturers use TTY bolts (torque to yeild) and any upgrade in performance demands a better fastener in this critical area. Blown head gaskets just don't leak, they can also ruin motors (oil/ water in the combustion chamber or worse, water in the oil!) Please believe me and others when we suggest to use new bolts, learn from many bad experiences and be glad you didn't have them.
Well said. That's why when I hear people saying that "B18C1 blocks can stand up to *** hp and ** boost without sleeves" and then you hear other people horror stories of cracked blocks on only a few pounds of boost. I'd rather spend the extra money and overkill it then end up ******* myself over.
Without knowing what is in the bottom end it's pretty hard to tell if you will need a set of studs. If you put the energy in the wrong direction, then it's all for not. Are you running higher compression? Do you plan to boost it in the future? If it's just for peace of mind, then measure your bolts. I am unaware of the measurement you will be looking for, but Google can solve that easy. After all, to be technical, you need to stretch all internal bolts when assembling a motor. So then all bolts are one time use? Not entirely. A stretch gauge will tell all. The bottom line is: If you can save $100, why not? If you don't know what you are doing inside a motor, then spend the money, and let someone who does, do it for you.
well next year im stripping the block gonna redue it all, not sure what the plans are yet, but im running out of time summers coming close so il be waiting till next fall.and i dont want to have any problems and i already got 3000 in the engine so whats 200$?? and have no problem with the head bolts have way threw the summer, thanks for all the help though
dyno day in 2 weeks
dyno day in 2 weeks
simplypinoyy
May 23, 2004 02:43 PM
