93 del sol si defroster not working?
has not worked for a couple years... fuses ok... not sure what it could be? the 4 ways work fine. I just replaced the turn signal relay. But the defroster does not work, i checked the connections.. all tight... thx, Kevin.
the button does not work when i press it, so both, sorry... the button beside the hazards does not light up, the windows do not defrost... at all.....
Does you car have A/C? If so, does the A/C work? The defrost mode for the front windshield and driver/passenger door glass requires the A/C, the cabin blower, and the mode control to work. Is this the problem?
Or are you saying the rear window defogger does not work?
Neth
Jan 19, 2018 02:14 PM
Unjockable
10
Jan 1, 2004 09:44 PM
