Noob Del Sol Questions
Hey guys my gfs got a '95 Del Sol and recently the pass and rear window stopped working while the drivers side window still works. I'm thinking it’s a relay or something? Anyone have the same problem or knows how to fix it?
Also, when she bought the car the previous owner had wired up an amp for the rear speakers. Her interior lights and cigarette lighter don't work. I was reading on some thread that if you don't do something to splice the wires in the head unit, and do something the interior/cigarette lighter won't work? I'm not to familiar with electrical issues so any help would be great. Thanks in advance.
Re: Noob Del Sol Questions
Look to your left on the window switches, there should be an extra switch which you probably don't know about yet, then play with it and you'll see its purpose. If that doesn't work then let me know and well go from there. Good Luck
and if your back window is not working then it is definately that 2nd switch
http://cgi.ebay.com/ebaymotors/93-97...617189002r8132
there's a picture for reference look for the switch that says "main" that might be your issue.
looks lyk u forgot to hit d4 switches on dat bish.....you gotta do dat then the trunk will hit hard like kimbo sl1ce!!
press one button car automatic start.....d4ts h0w i d00000!!
Definitely the "main" switch on the power window switch area. Flip it and it should work again.
Dome light and cig lighter is probably a fuse.
Hey there was no sarcasm in there, somebody else made it sound like that. I was just trying to be descriptive and helpful with the picture. I have seen a lot of repetitive thread on other forums with the same issue and people don't know about the switch. your topic is "noob del sol question" and the first place to send a noob to look is at the main switch, my bad for trying to help.
itsmejto
11
02-02-2012 07:01 AM
martin4o2005
06-16-2011 01:48 PM
SilverGT
01-28-2007 10:26 PM
