1st gen Rear hub 4 lug Question
First off lemme say this isnt for a normal crv. Its in an integra gsr. I'm putting the rt4wd system in it and am looking for a solution to a problem. I have searched and searched and cant find enough information to come up with a hub that can replace the stock rear 5 lug with a 4 lug. I know this isnt a normal thing for crv owners to do, but no one else has any info. The rear spline is much smaller than most fwd hubs and I'm pretty sure the od of the hub is 43. Lemme know if im wrong. Any info at all is helpful. Thank you. BTW link in the sig for the build if anyones interested/has any inputs
Srry. short story is, im looking for a standard 4 lug hub that will fit the 5 lug crv bearings and cv shaft. sorry for the confusion
The bolt pattern for the rear spindle is the same on all the other '88 - '00 Civics/'90 - '01 Integras so I'd say they have a pretty good chance at working. I'm not sure if the spline count on the outer joints is the same or not.
Wagovans never came in 4WD. They were all FWD. Wagovan is a spec level of a Civic Wagon.
I know RT4WD Civic Wagon RCA's are different from all other EF/EG/DC etc etc
Rally sol pm'd me that the wagons rear hubs won't fit in the crv bearings, but that the whole bearing assembly will swap with no modification.still not sure if the crv outer cup will fit the wagons hub.
boostedcivicsir
Mar 27, 2007 05:18 PM
