Who make a good tps
I prefer Dorman, just because I have never had an issue with their products. I have had friends use Omni though and never had issue. I know Dorman has a lifetime warranty. I would just go with them. The price difference is negligible.
It might be I'm gonna try one more and see what happens
I'm having problem with my car running lean at certain throttle positions and can't seem to figure it out. I've also had a few shops look at it and they can't figure it out either
Wish someone in Alabama could fix it for me
Stop throwing your money away. The chances are that all of your TPS have been fine. Get a multimeter and properly troubleshoot the three TPS wires. If they're fine, swap in a known good ECU.
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
have you checked the TPS outside the car? do they all give you the same issue then? check the wires for continuity and resistance while moving the harness around, you might have a break/short somewhere. finally, run new wires to the ECU from the TPS.
I don't get the same symptoms from each one
And not how do I check the tps out of the car?
And I will check the wires this weekend. It was on my plans anyways because I've been thinking it could be my harness
As mentioned before, give it a test and it sounds like the TPS is the result of the problem not the cause.
Report back and be happy to help sort it.
Ok I texted the wire from the tps to the ecu seems good didn't act like any breaks in it when I was moving around. I was testing ohms on the wire and would get around 5.5 ohms
Tested a few tps out of the car got same results on all of them. So I guess the all good
Is there anything else I can do. I need to get it fixed so I don't harm my motor with it running this lean
crnimacak
Jan 19, 2006 04:59 PM
