Brake problems
Old Apr 1, 2013 | 06:50 AM
CNelms's Avatar
Default Brake problems
I hope i dont lose everyone but here we go.
I changed my pads and rotors in my 96 civic ex now when i brake going backwards it shakes and makes an aweful noise also when driving and braking regularly the passanger side seems to only hit the rotor at a certain spot.
I did not bleed the lines i wouldnt think it would cause all this problems but if i knew what it was i wouldnt be posting this
Lastly i did have to shave down the pads due to them being to big to fit under the caliber it was done with a belt sander
Old Apr 1, 2013 | 06:52 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Brake problems
Urg. You should not have had to grind down anything.
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
So you did not depress the caliper?
The Grumpiest
The caliper piston? Just sounds like he simply swapped out pads.
Old Apr 1, 2013 | 06:54 AM
CNelms's Avatar
Well i had ordered the pads and rotors from 1AAuto and they cleare it a little but needed about .1MM to clear it. I had followed a how to on here when doing it and followed it step by step except for bleeding the lines
Old Apr 1, 2013 | 06:57 AM
CNelms's Avatar
I swappe the rotors and pads i compressed the piston when putting it back in but it still didnt clear it by a little bit so i shaved the pads so the caliber would clear it and bolt back into place i think the only thing i forgot was to bleed the lines
Old Apr 1, 2013 | 07:01 AM
doctorake's Avatar
Community Builder
I have never heard of having to shave the pads, are you sure they were the right pads?
Old Apr 1, 2013 | 07:03 AM
CNelms's Avatar
They shouldve been but i really cant be 100% sure i have ordered from them before and they seem good about sending the right stuff do you think that could cause all those problems though
Old Apr 1, 2013 | 07:15 AM
CNelms's Avatar
I just called their techs and they said that the pads isnt lines up with the rotors yet im just gonna have to ride on it some until the pads level out with the rotors
BrakeExpert
Suspension & Brakes
Apr 9, 2012 05:59 PM
antig24
Aug 13, 2011 07:43 AM
BrakeExpert
Suspension & Brakes
Sep 13, 2008 09:11 AM
B18CYAAA
Oct 1, 2003 08:18 PM
functionFiRst
Oct 2, 2002 09:49 PM
