Suspension & Brakes Theory, alignment, spring rates....
brakes squeaking, question
Old Mar 30, 2013 | 04:27 PM
tallguy21's Avatar
Default brakes squeaking, question
I checked my pads, they still have at least half life left in them, The rotors seem to be the same, but ever since I left my wheels off while I was doing my control arms, axles etc......my car was basically up on jack stands for about two weeks and ever since then i've been hearing squeaking/rubbing type of deal when I come to a stop.....while driving everything is fine....any ideas on what that could be?
Old Mar 31, 2013 | 01:58 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: brakes squeaking, question
The brake dust shield is up against the back of the rotors. Use a flat screwdriver/pry bar to straighten it out.
Old Apr 1, 2013 | 08:35 AM
tallguy21's Avatar
Alright... Thanks... I'll check that out
Old Apr 1, 2013 | 08:42 AM
NVturbo's Avatar
O.G. triple O.G.
Yeah...the shield usually get bent and most folks don't realize it until the wheels are back on and the car is back on the ground.
Old Apr 19, 2013 | 03:51 PM
tallguy21's Avatar
Ended up being I'm assuming a crap ton of dust/grease... Took the wheel off to check the pads and rotor and everything was good... Sprayed the crap out of it with purple power, sprayed it down with a hose... Barely any squeak at all in comparison to what it was before... Appreciate the help
LAUREN minter
Suspension & Brakes
Jan 26, 2016 06:53 AM
erikiksaz1
Mar 27, 2008 05:21 PM
pcguy760
Nov 19, 2007 10:51 PM
racacura
Nov 26, 2006 08:36 AM
1fastGSR
Jul 13, 2001 06:20 PM
