91 civic hatch won't start
Old Mar 30, 2013 | 01:58 PM
Syke909's Avatar
Default 91 civic hatch won't start
I just swapped the engines in my car cause the one in it stopped running but I swapped it with another stock one and put my tranny and starter on and now when I try to start it the starter only clicks once so I bench tested it and that starter was bad. I went to autozone and bought a new one but its still doing the same thing. Everytime I try to crank it the starter clicks once and the dash lights turn off. I'm clueless right now any help will b great.
Old Mar 30, 2013 | 02:27 PM
mpt.ed3's Avatar
Default Re: 91 civic hatch won't start
have you tried a new battery? not saying that is the culprit but it is a good place to start
Old Mar 30, 2013 | 02:44 PM
Syke909's Avatar
Tested the battery and found out it was low so I have the battery on the charger right now. Ima give it another try I'm about an hour and see if hat was the problem
Old Mar 31, 2013 | 12:06 PM
Syke909's Avatar
Ok so I ended up getting a new battery and now it starts but check engine code 5 for a dpfi set up and I'm not sure what that is
Old Mar 31, 2013 | 01:32 PM
jdm_rb20's Avatar
dpfi is "dual point fuel injection." Sounds like you either installed a motor that isn't the same as your original motor (therefore, not compatible with your ECU) or it is more highly likely that you don't have all the sensors plugged in correctly. If all the sensors, injectors, etc are plugged in correctly, then I would start by testing the 2 injectors in the motor you just put in.
Are you certain that you didn't have code 5 on the old motor also?
Old Apr 6, 2013 | 11:59 AM
mpt.ed3's Avatar
does it run fine?
inaety
Jun 24, 2011 12:57 AM
JDMdb8isO
Feb 6, 2011 12:58 PM
DriveSlowHomie
Jan 26, 2010 10:31 PM
xander1100
Oct 18, 2009 07:56 PM
allsho
Aug 5, 2008 04:30 PM
