Need some opinions if I should still use this head on my build.
Old Mar 30, 2013 | 08:37 AM
Trppen37's Avatar
Default Need some opinions if I should still use this head on my build.
My block is being sent off for sleeving and machine work, while putting together my head, my builder spotted something. There is a small nick as u can see in the pictures. I want your guys opinion if I should still use this head or use my stock one? The reason I wanted to use this head because it has already been worked on... Is the damage really significant to where I shouldn't use it? If I get it milled, I run the risk of higher compression. Don't know if I can go higher. My setup is a b16a bc stroker kit 85mm bore/ darton sleeved with 12.0:1 CP Pistons. I live in Japan so gas quality is better but still ...
Old Mar 30, 2013 | 10:28 AM
B_Swapped93's Avatar
Default Re: Need some opinions if I should still use this head on my build.
You could get it re-surfaced ?. Afaik less is taken off that way over milling, those nicks don't look that bad imo.
Old Mar 30, 2013 | 02:11 PM
Brandon_ek's Avatar
Do a nice resurfacing and you should be good
Old Apr 1, 2013 | 01:59 PM
98vtec's Avatar
moderator emeritus
I would not be concerned with it, personally. Its not on the mating surface and its too small, IMO, to be worried about it creating a hot spot. If you ever counterbore the head, it will take care of it.
Old Apr 1, 2013 | 02:08 PM
raverx3m's Avatar
is that oversize gasket?
why not mill it to match the cylinder diameter
Old Apr 1, 2013 | 02:15 PM
98vtec's Avatar
moderator emeritus
you dont use a mill to do that.
lazyxmofo
Nov 26, 2010 10:05 AM
WishinItWas
Aug 22, 2007 02:58 PM
solman74
Sep 11, 2006 09:11 PM
I got a honda
Aug 21, 2005 06:22 PM
