skunk 2 alpha throttle body 70mm and 70mm intake manifold b16 issue
Old Mar 29, 2013 | 11:49 PM
Henson112233's Avatar
Default skunk 2 alpha throttle body 70mm and 70mm intake manifold b16 issue
after I installed my skunk2 alpha tb was installed and blox intake manifold, it idles high and makes a screeching sound sometimes and it smokes and runs rich. my friend tellse to take out the thermostat to fix the smoking problem. I think I need a tune to compensate for the increase in air flow but I just want the car running normal until I get enough for a tune. is the crazy idle due to vacuum leak which I'm sure I sealed all of them? any ideas to fix idle and smoking problem? I tried to mess with the tps sensor to idle less but I don't know if that works.
Old Mar 30, 2013 | 05:14 AM
grumblemarc's Avatar
The Grumpiest
Default Re: skunk 2 alpha throttle body 70mm and 70mm intake manifold b16 issue
Originally Posted by Henson112233
skunk2 alpha tb was installed and blox intake manifold...I think I need a tune to compensate for the increase in air flow
That's your issue. No getting around it.
Old Mar 30, 2013 | 05:17 AM
B_Swapped93's Avatar
mine did that at first(running rich). The idle can be adjusted via the idle screw then calibrate you'r tps. but first check to see if you have any vac leaks im assuming you have more than "bolt ons" with that 70mm tb you're running.....
wils92sedan
10
Dec 25, 2011 04:26 PM
Gho$t
Nov 10, 2009 10:26 PM
crxfreak1117
10
Oct 29, 2007 07:35 PM
b16a3delsol
Aug 15, 2007 09:29 AM
dplatt
Jul 14, 2002 09:00 AM
