Help Please! Fuel Not Priming
So I swapped a d16y7(block/y8(head) into my ej8, with everything plugged in, my fuel isn't priming. What could be the cause(s)??
Fuel pump fuse 13 is good, I replaced the fuel pump relay and tried it again, but no go.
Next I'm going to replace the fuel pump and fuel filter.
What other solutions could there be? Thanks guys!
And also! My car had ev6 fuel injector wires setup from past turbo system so I had to splice d16z6 fuel injector harness pigtails and use the z6 fuel injectors. What is the wiring diagram for fuel injectors supposed to be from left to right or vice versa??
Again, thanks.
Again, thanks.
Cameron60
Jan 16, 2007 06:04 PM
HondaEF
Jul 19, 2004 06:34 AM
