Honda Timing Belt
Old Mar 28, 2013 | 05:53 PM
nskbob's Avatar
Default Honda Timing Belt
I am replacing timing belt for Honda accord 2000 that has only 75000 miles now. Do I replace water pump also?
planning to by from .importrp.com. Any suggestions?
Old Mar 28, 2013 | 06:04 PM
doood's Avatar
been there done that
Default Re: Honda Timing Belt
might as well since you'll have it apart anyway. just use oem.
Old Mar 28, 2013 | 06:30 PM
1998GsRIntegra's Avatar
It's standard practice to replace the water pump with the timing belt, but I know of people that have near and over 300k miles on their original water pumps. It's up to you, but it is standard dealership practice to do the water pump with the timing belt.
Old Mar 29, 2013 | 04:54 PM
nskbob's Avatar
Thank you, doood and 1998gsrIntegra. I will replace both and will go with oem. Going to order from importrp.com
Old Apr 4, 2013 | 02:27 PM
nskbob's Avatar
I placed a phone order with Mike from importrp.com. I received it today. That is superfast. I am impressed.
Old Apr 4, 2013 | 02:30 PM
nskbob's Avatar
Ordered OEM one as it is 45% cheaper compared to the genuine item. Any recommendation on the coolant brand that I have to buy?
Old Apr 4, 2013 | 03:13 PM
datbumper's Avatar
OEM lol.
Old Apr 6, 2013 | 12:55 PM
nskbob's Avatar
Drives like new. I guess oem is a good choice
Old Apr 6, 2013 | 10:27 PM
PraizEK9's Avatar
use green coolant, do not use orange coolant ever on Honda's. also do a 50/50 mix water/coolant if you buy coolant that is not already 50/50. recommend replacing water pump and tensioner since your already there, also take a look at your crank and cam seals, if they look like they are leaking/seaping recommend to replace those too since you are already there. if you are doing the t-belt yourself and run into problems taking the crank bolt off get the 3/4 inch drive impact gun from harbor frieghts, it will save you time and knuckles.
Old Apr 8, 2013 | 10:37 AM
nskbob's Avatar
Thanks PraizEK9.
I used Honda supplied coolant and it was replaced by a mechanic. Car is running fine now.
Old Apr 15, 2013 | 06:37 AM
PraizEK9's Avatar
Great i am glad to hear your cars back up and running, nothing better than the feeling of having your car back knowing it is in good shape. keep up on your maintenance and it will last you forever.
chicken18
16
Jul 31, 2018 05:03 PM
wasp9166
44
Mar 9, 2014 11:47 AM
globy123
18
Aug 2, 2008 09:53 AM
1ntensiveVTECivic
Dec 19, 2003 10:29 PM
