Car gets hot but never overheats
Old Mar 28, 2013 | 04:57 PM
RuneRavenX's Avatar
Default Car gets hot but never overheats
Hey guys, my CRX with a D16a6 had no thermosat when I bought it, and took forever to get to operating temp. Now that I have one installed, the temp usually sits right below the "H" mark, which is way hot, but never reaches the mark. Sometimes it will go down to halfway, but standard temp is about 1/4 of the gauge. I ordered my thermostat from Rockauto, it's a BeckArnley. The standard opening temp is 172, fully open at 194. It is possible that I have one that is rated to open at a higher temp, thus causing my car to always run hot? Any help is appreciated.
Old Mar 29, 2013 | 10:28 AM
ef_cowboy's Avatar
Default Re: Car gets hot but never overheats
Check if the temp sensor and fan switch are out of range... Or just replacem
Old Mar 29, 2013 | 11:58 AM
RuneRavenX's Avatar
Temp sensor is brand new. I had thought about replacing my fan switch, but since the fan was still working I left it alone. I will replace it in a few days. If that doesn't work I will check thermostat to see when it starts opening, and replace if it opens at a higher temp.
Posted from Honda-tech.com App for Android
Old Mar 30, 2013 | 04:54 AM
~sp33~'s Avatar
EFB055
Does the fan cycle on and off with the car left to idle with the A/C off?
Old Mar 30, 2013 | 08:41 AM
RuneRavenX's Avatar
Sometimes, but not like it should. It is supposed to come on twice before reaching operating temp. But it doesn't come on until long after that.
Old Mar 30, 2013 | 04:28 PM
~sp33~'s Avatar
EFB055
Try removing the thermostat and heating it on the stove to see if you can get it to open before it hits boiling point.
Old Mar 30, 2013 | 05:13 PM
facciol93's Avatar
^^ make sure your termostat is ok.
Old Apr 2, 2013 | 04:45 PM
RuneRavenX's Avatar
it's brand new. I'm thinking it is likely good. but I'm still gonna replace with one from a parts store that is rated for 170
torino420
May 5, 2013 08:07 AM
PphamEK
Apr 6, 2009 07:00 AM
JoeCereghino
17
Nov 30, 2008 08:41 PM
b18c195
Aug 2, 2006 09:58 AM
tianporn
15
Feb 20, 2005 10:56 AM
