Grinding/ chirping sound.. Help!!
Old Mar 27, 2013 | 06:19 PM
xluigix47's Avatar
Icon3 Grinding/ chirping sound.. Help!!
I have an automatic 94 civic ex, and there's a grinding/ chirping sound coming from under the hood when im driving. It only does it when im accelerating, no matter how soft i touch the gas pedal, i can hear it. It doesnt do it any other time than when i give it gas and going forward, not reverse, neutral or parked. And the more gas i give it, the louder and faster the sound gets. what could it be???
Old Mar 27, 2013 | 06:33 PM
vega5415's Avatar
Default Re: Grinding/ chirping sound.. Help!!
First thing that comes to mind is wheel bearings. This is only a guess from the info youve provided
Old Mar 27, 2013 | 07:01 PM
crazyhouse2011's Avatar
This is probably not the case, but is definitely worth looking into: sometimes when alternators go bad the bearings wear out and it will give off a characteristic whining and grinding noise. Obviously this gets worse when you put a load on it, such as the headlights, and can get louder when you accelerate. However, since you said it doesn't do it in neutral, I don't think this is the problem. Couldn't hurt to take it to AutoZone or Advance Auto Parts and have them run a free multimeter test on your electrical system (battery and alternator). Good luck.
Old Apr 5, 2013 | 07:59 AM
xluigix47's Avatar
Is there a chance it could be something in the engine? You can't really hear the sound when the car is cold but after warm up, its louder.
Old Apr 5, 2013 | 08:14 AM
CFiannotti's Avatar
How old are your front brake pads?
Old Apr 5, 2013 | 10:45 AM
xluigix47's Avatar
The brake pads are fairly new, replaced them in not so long ago
Old Apr 9, 2013 | 09:25 AM
vega5415's Avatar
@ crazyhouse2011 you sound more accurate than my first guess
Check the idler pulley it could be going out when the bearing goes out to you get the grinding noise sometimes it catches and gets stuck which causes the belt to spin around the pulley cause the chirpping
Old Apr 9, 2013 | 09:28 AM
EgNoobCx's Avatar
Pop the hood and have someone step on the gas while on neutral and see if you can pin point the location of the noise.
if it only happens when the car is moving then i would guess a bearing or water pump. Check for leaks.
Does your tranny shift fine?
Old Apr 9, 2013 | 09:44 AM
Fnix's Avatar
Does the car vibrate alot? Maybe motor mounts.
Old Apr 9, 2013 | 04:12 PM
xluigix47's Avatar
We just replaced the water pump last weekend, tranny feels fine and the engine doesn't vibrate alot
Old Apr 16, 2013 | 04:45 PM
xluigix47's Avatar
Someone told me the sound is "engine pinging" how could i fix this?
N4m
Aug 8, 2012 12:53 PM
kevinf_69
20
Feb 18, 2009 11:44 AM
DelSolMarine
Aug 21, 2007 07:01 PM
Jeroen1000
Oct 27, 2006 01:30 AM
6thgenaccord
Sep 26, 2006 11:21 PM
