IACV Issue
Old Mar 25, 2013 | 03:35 PM
Daz-E's Avatar
Default IACV Issue
I have a 97 hatch with a "Mini-Me" swap in it that I need to smog(Star smog). I bought the car this way and its been really reliable so far(I had it for a year now). I need to smog this car and I thought by putting the stock pcm back in it would be fine. Apparently the p28 that is in is tuned to make it run cause when I put the stock pcm in I have a Cel for IACV circuit. I did a little digging and found that it was a 3 wire made to a 2 wire IACV. So the orange signal wire is not even attached to anything.
The p28 has an adapter harness that it plugs into to work but I guess it is not hooked up to OBDII port.
Is there a way around this ?
Old Mar 26, 2013 | 08:53 PM
Daz-E's Avatar
Default Re: IACV Issue
Anyone ???
Old Mar 28, 2013 | 04:46 AM
Lizardslap's Avatar
that computer is obd1
and if you still can have a 3wire iacv (on a y7 throttle body) and plug that orange wire plugs into a13
and Im guessing it originally came stock with an obd2a computer
http://www.phearable.net/tech/wiring...schematics.gif
http://www.phearable.net/tech/wiring/wiring.96-98_2.jpg
plz explain what motor you have more details about the car
Old Mar 28, 2013 | 04:51 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
You will need an obd2 ECU if they run a diagnostic.
Old Mar 28, 2013 | 02:13 PM
Daz-E's Avatar
From what I know its a stock 16y7 block and a 92-95 vtec head(IDK which one), 2 wire vtec wired to a p28 using a adapter harness t plug into the stock wiring.
I want to use the stock ecu(OBDII). Maybe the signal wire(orange) can be jumpered somewhere else for the ecu to recognize it and turn off the cel. IDK.
Will a d16y7 intake work on a 92-95 vtec head ?
Old Mar 28, 2013 | 04:25 PM
Lizardslap's Avatar
cant help you with that intake working on another head I have no information about that
but you need a d16y7 throttle body for that 3 wire iacv to work along with the plug for it
or you could try and source an obd2-a single over head cam vtec manual ecu and try that in its place and then it would look for a 2 wire iacv mabey
I just know how to go from 2 wire iacv to 3 wire iacv
Old Mar 28, 2013 | 05:41 PM
Daz-E's Avatar
I'm not sure the vtec ecu would plug in. The adapter plug eliminates the diagnostic port(assuming) and if I have to use it again to plug in a vtec ecu that would defeat the purpose. The intake I'm not sure it would bolt up either because it is completely different. I appreciate the help man , thanks !
Old Mar 28, 2013 | 06:21 PM
grumblemarc's Avatar
The Grumpiest
Just get the correct head and run the correct ECU. Whomever thought this was a good idea in CA of all places was an idiot.
No matter what you try in this configuration you're going to fail.
Old Mar 28, 2013 | 07:42 PM
Daz-E's Avatar
That's what I'm gonna have to do ! When mods like this was done it was easier to get around the smog with a hookup but now Cali has the new smog program that targets smog shops its either really hard or expensive to get a hooked up smog.
Old Mar 28, 2013 | 07:55 PM
yztzzxga's Avatar
Old Mar 29, 2013 | 03:57 AM
Lizardslap's Avatar
that adapter on the ecu plugs should just unplug and leave the original obd2-a plugs there
h22accord101
Mar 3, 2015 12:44 PM
Daz-E
Southern California
12
Apr 22, 2013 07:07 PM
youryanyou
Feb 9, 2011 12:43 AM
boricuacivic
Apr 6, 2009 09:02 AM
Pfieff
Dec 2, 2003 05:54 AM
