Eg hatch stays on after key is removed
92 eg hatch with an ls swap stays on after I remove the key here a slight buzzing under the hood have to kill the car manually then disconnect the battery. Something is staying on and drawing power if I don't. Please help!
None that's the weird thing. Changed the ignition harness cuz that's what I thought could be wrong changed the cluster. Thought it was the fuel pump hard wired
Doubtful. At the very least you need to remove that kill switch and test the ignition switch. And the fuel pump is hard wired?
also pull your starter and and test it. could be a short in it... if the starter is fine, then you could have a short, bad ground, blown fuse, anything
Austinsharp73
Mar 13, 2019 10:10 PM
EGhachiback
12
Jun 11, 2014 03:44 AM
93grayeg
Oct 16, 2009 02:07 PM
Honda Virgin
Jun 2, 2004 12:34 PM
jdmcivicferio
41
Jan 14, 2003 12:45 PM
