99 gsr cam question
Old Mar 25, 2013 | 01:07 AM
Yomama182691's Avatar
Default 99 gsr cam question
I've got a 99 gsr with 247xxx miles. Cold air intake and skunk2 intake manifold. I'm going to be doing an fi build but not till after I rebuild the motor or buy a new one. Question is can I buy and install a turbo cam and run fine without it being turboed?
Old Mar 25, 2013 | 05:28 AM
doood's Avatar
been there done that
Default Re: 99 gsr cam question
you dont need turbo cams. stock gsr cams make plenty of power with boost.
Old Mar 25, 2013 | 08:32 AM
Really? That's awesome. Thanks. Another question. Ill be rebuilding the motor before I boost. Ill only be boosting prolly no mor than 10. Do I need to upgrade any internals for the boost?
Old Mar 25, 2013 | 09:23 AM
DirtyDA9's Avatar
Ive seen 700+hp on gsr cams.
Old Mar 25, 2013 | 10:02 AM
racebum's Avatar
the psi isn't important. cylinder pressure and hp are. if you get one of the new garrett GTX turbos, like a 3071 or 3076 you can make really strong hp numbers on low boost.
this is my old car the new owner put a gtx 3071 on.
engine finally went when the head lifted
in short if you're doing a rebuild for boost use a 4032 forged piston, better rods and install arp head studs
it's too easy to crack piston ringlands with cast pistons
Old Mar 25, 2013 | 03:56 PM
Ok thanks. What's a good rod? And what about crank and bearing. Valve and springs. Do any of these new to be upgraded.
Old Mar 25, 2013 | 04:22 PM
doood's Avatar
find somebody's build thread in the forced induction forum that's making the power you want and copy their build. it really is that simple.
Old Mar 25, 2013 | 05:21 PM
racebum's Avatar
forced induction forum would be a good place to start
or call myles at englishracing.net
he also posts here and could walk you through what to buy for a build. pistons generally mahle or supertech since they can be setup tighter than a 2014
rods, set of $200 manleys or eagles will keep up with the stock sleeves. as for valves buy all new exhaust valves, you can reuse your intakes, obviously have a valve job done and measure the guides to see if they also need to be replaced. use oem honda valves. their failure rate is just lower than a lot of aftermarket stuff.
Old Mar 26, 2013 | 01:40 AM
Thanks for the input guys. Will be checking into someone's build.
silverdcteg
Sep 17, 2024 05:34 AM
milanoteggy
Jul 26, 2012 11:54 AM
JustHere4ADay
Dec 17, 2007 08:37 AM
playalistic2
Jun 23, 2005 08:41 PM
BtMplayboi
Feb 28, 2005 08:44 PM
