Transmission & Drivetrain Gearboxes, Differentials, Clutches
Bent Gearshift Rod
Old Mar 24, 2013 | 10:31 AM
tdizz07's Avatar
Default Bent Gearshift Rod
Hey everyone,
I'm just curious how hard it is to replace number 1 in the below diagram.
I was having a leak in my hydro GSR transmission in my 94 Civic EX and I changed the seal but I still have the leak so I got back under after doing some searching and realized how bent it is and that's what is probably causing the leak.
Is it overwhelming opening the case up for the first time? I've done almost ever other thing I can think of to a EG or B/D series besides opening the transmission.
Thanks for the help!
Old Mar 24, 2013 | 12:56 PM
Aquafina's Avatar
Default Re: Bent Gearshift Rod
Highly unlikely it is bent. Pull the linkage off, pull it as far out as possible and put a straight edge on it. If its bent you would have more problems than just a leaky seal.
Old Mar 24, 2013 | 01:35 PM
tdizz07's Avatar
You don't think that looks bent? I just replaced the seal and it still leaks.
Old Mar 24, 2013 | 06:30 PM
4g hatch's Avatar
if it was bent i would think you would have issues changing gears, hows the axle seals? they will leak and trail other places making it look like leaks in other places
Old Mar 24, 2013 | 07:09 PM
tdizz07's Avatar
I don't feel like it's bent a lot, just enough to cause a gap in the seal and make it leak. It could be the other seals though, I'll check this week and let you know.
Old Mar 25, 2013 | 03:32 AM
94EG8's Avatar
Seagull Management
No, the rod comes out at an angle on B-series transmissions, that looks perfectly normal.
Old Mar 26, 2013 | 03:16 PM
tdizz07's Avatar
Awesome. Thanks. That's why I come here.
MinimusMaximus
Sep 30, 2011 02:37 PM
SiRkid
Jul 3, 2009 06:51 PM
94CivicSi
Jun 14, 2003 07:03 AM
