1992 CIVIC IACV BOLTS PROBLEM HELP
Old Mar 24, 2013 | 01:54 AM
ameer_vtec99's Avatar
Default 1992 CIVIC IACV BOLTS PROBLEM HELP
hello HT
yesterday i remove idle air control valve to clean it every thing was fine but when re install it i damaged the thread in the down hole bolt and the bolt lose now and my car idle like b**** this is my dd car i dont have another car
what can i do to fix it ? should i remove the the intake and make new thread or or i try to change the bolt i am confuse dont no what to do HELPPP please
thanks guys waiting your suggestions
Old Mar 24, 2013 | 07:37 AM
strategy400's Avatar
Default Re: 1992 CIVIC IACV BOLTS PROBLEM HELP
Either remove the intake or remove some motor mounts and turn or hoist/move forward the engine to get access for helicoil but either way that sucks. Try jamming a toothpick or small diameter copper wire in there see if it will catch some threads/tighten up any. Cant hurt.. Slightly larger/longer bolt?
Careful tightening into aluminium. Sometimes it has been overtightened previously and can't be helped.
Always consider surgery outcomes on a dd. Maybe some type of clamp can hold the IACV in place until you can fix it right.
Old Mar 24, 2013 | 08:07 AM
thanks
i will try to make new thread if its possible without removing the intake otherwise i will remove it and fix it .
Old Mar 24, 2013 | 08:57 AM
Fnix's Avatar
It doesnt take long to remove the intake.
Old Mar 24, 2013 | 08:58 AM
HondaPartsHero's Avatar
Technical Hero
Do you have access to a tap and die kit?
You could try to find that thread pitch and try to chase the threads first and see if that will fix it.
Old Mar 27, 2013 | 03:59 AM
i solved the the problem by using a high quality gasket maker for the time been until i have time to remove the intake and fix it or but another one for better performance
thanks guys for the advises .
one more question .
now the car idle fine but when i accelerate the pedal gas the car would not go only if the rpm is over 3k if its below that starts shaking and i noticed when i turn the key to on II
i cant hear the fuel pump prim for 2 seconds any ideas for now before i destroy it because its driving me to be crazy i like my car i dont want heart it .
if any one knows what is the causes for this problem please help
i will read the codes today and i will let you know .
regards everybody
Old Mar 28, 2013 | 01:46 AM
it was really funny about this car
yesterday i check the wiring and all sensors positions.when i reach to the TPS sensor i found one wire not connected to the plug so i just change the plug and reset the ecu everything is perfect now .
thanks guys
ameer_vtec99
Mar 24, 2013 01:52 AM
00DC2
Jul 22, 2009 06:18 PM
lmike6453
Jun 30, 2008 07:31 AM
cc11386
Nov 2, 2005 01:31 PM
allmotorEG-SI
Oct 3, 2001 11:14 AM
