1994 Honda Civic DX Check Engine Loight
Old Mar 23, 2013 | 11:44 AM
Hondito94's Avatar
Default 1994 Honda Civic DX Check Engine Loight
My 1994 Honda Civic DX the check engine light came on. I took it to a mechanic, he tested it and said that it meant Code 9. What does Code 9 mean and what is wrong with the car as far as what part is deffective and I need to repair......Thanks in advance Hondito 84
Old Mar 23, 2013 | 12:31 PM
EZ600's Avatar
Default Re: 1994 Honda Civic DX Check Engine Loight
wrong forum. go try the civic specific forum, everything here is 70's-80's hondas.
Goodluck
Old Mar 23, 2013 | 01:52 PM
Chriser0's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
I think its this---9 CYP - cylinder sensor
Old Mar 23, 2013 | 01:55 PM
Eddie's Avatar
Master Ninja
How does your mechanic not tell you what it means? And how do you not ask?
datsol94's Avatar
Code 9 is a cylinder position sensor. Is the car misfiring or running abnormally?
Old Mar 23, 2013 | 02:17 PM
B_Swapped93's Avatar
^Agreed.
The last post in this thred might help you out here:https://honda-tech.com/forums/acura-integra-6/check-engine-light-code-9-obd1-2788506/
Old Mar 23, 2013 | 04:37 PM
Hondito94's Avatar
Thanks
Old Mar 23, 2013 | 04:42 PM
Hondito94's Avatar
No is not, what is a cylinder position sensor and what is that telling me, that one of the 4 cylinders is not working properly or what.....I definitely appreciate your reply to this question. Thanks
Hondito 94
Old Mar 23, 2013 | 04:45 PM
Hondito94's Avatar
He did not now, and yes I asked but he said that he had to check in the book to see what it was. He did say that it wasnt nothing serious that I could still run the car....what can you advise or tell me about code 9 since it seems that you now what it is
Old Mar 23, 2013 | 06:48 PM
Hondito94's Avatar
Old Mar 23, 2013 | 06:49 PM
Hondito94's Avatar
It runs fine, no misfire or anything like that
civic565
Honda Civic (2001 - 2005)
12
Apr 23, 2014 08:04 AM
williamer5494
Jul 15, 2013 10:38 AM
chevyluver85
Dec 24, 2008 09:32 AM
Y_my_91
Jul 2, 2008 04:59 PM
badpootie
Acura TL, RL & ZDX
Mar 29, 2005 09:20 AM
