My headlights stopped working
Old Mar 23, 2013 | 08:43 AM
another integra's Avatar
Default My headlights stopped working
Hi everybody, I have a 1993 Honda Civic CX. The low beams & dash lights stopped working, but the blinkers & high beams still work. I have checked the fuses under the dash and they're fine, although one socket has a 30amp in it when it should be a 10amp it says. I noticed that the switch to turn the headlights on became a little harder to turn before they went out, and now that they don't work, the switch turns easier. I also smelled an electrical smell while driving the car. Do you know what it could be? Any help would be appreciated.
I think it might be the turn signal switch, but I would like to know what you others think, before I spend money on one. I did do a search, but people had HID's, or their issue wasn't as similar.
Thanks
Old Mar 23, 2013 | 08:55 AM
grumblemarc's Avatar
The Grumpiest
Default Re: My headlights stopped working
Why is there a 30amp fuse? What else has been modified on this car?
Old Mar 23, 2013 | 08:56 AM
The car is all stock, just had the wrong fuse.
Old Mar 23, 2013 | 09:00 AM
The Grumpiest
Did you check fuses underhood?
Old Mar 23, 2013 | 10:51 AM
Yes, they're fine. I forgot to mention that my dash lights stopped lighting up, also.
Old Mar 23, 2013 | 10:59 AM
The Grumpiest
Sounds like the switch.
neb11ihtut
Jul 19, 2007 12:29 AM
92wraith
Oct 12, 2005 06:31 PM
sillvercivicgsr
Jan 12, 2004 02:43 PM
