b16 swapped 98 hatch bogging in low rpm
hi was wondering if any one could help with my bogging issue, in first when leaving a light the car boggs a little like almost dies, but after 900-1000rpm its cool, ive check my fuel lines and injectors, was wondering if there is any else i should check that could be causing this issue
Re: b16 swapped 98 hatch bogging in low rpm
p72 ecu, has a check engine light but havent had the chance to pull it a code for it,and to be honest i dont kno how to check timing on it
mine does the same, but its a drivability map issue on my s300, timing could be a issue but you can ask the local tunner to do a time light test for cheap ($25)
ill go pull the code after work, but i dont kno how to read the check engine but its just a quick flash when i turnthe key if that helps at all....but ill go pull the cel code at autozone after work
rhdins
06-11-2008 10:13 AM
type Gendy
04-21-2003 04:48 PM
