Suspension & Brakes Theory, alignment, spring rates....
alighnment
Old Mar 21, 2013 | 10:01 AM
surfhound's Avatar
Default alighnment
My 92 stock accord pulls to the right a little when tacking, I would like to adjust it myself, any advise would be great.
Old Mar 21, 2013 | 05:23 PM
DO-WORK-SON's Avatar
Default Re: alighnment
Not sure what tacking means but you can google "DIY alignment" and come up with many ways, of course having a shop do it is always HIGHLY suggested but doing it yourself is possible with a few simple tools, string, strait edge, maybe a level if your doing camber also. first insure your steering wheel is strait, then stretch a string across the face of your front and rear wheel on one side of the vehicle, then hold the strait edge to the face of the wheel in question, if its off it will be obvious, and then make adjustments till the strait edge is inline with the string as close as possible. if its really off you need to keep checking that your steering wheel is still strait and isnt moving as your making your adjustments. Again this is one method that can get you close but alignments should probably be left to professionals when at all possible.
Also check this threat out lots of good stuff here.... https://honda-tech.com/forums/showth...=267237&page=4
Old Mar 21, 2013 | 05:55 PM
Libertariat's Avatar
Ek Forever y0!
When tacking?
Are the tires properly inflated?
What are the current alignment specs?
easyFOsheezy
Aug 25, 2010 12:26 PM
skeg8
Mar 15, 2006 01:16 PM
.water
Suspension & Brakes
Feb 9, 2006 10:39 AM
zeroluck
Suspension & Brakes
Jan 11, 2006 05:42 PM
yohan
Jan 28, 2003 07:45 AM
