1996 ex with d16z6 swap
Old Mar 21, 2013 | 04:02 AM
Joe Hall's Avatar
Default 1996 ex with d16z6 swap
i am in need of some serious help.last week i went and had my valves adjusted and now my car is still ticking running really rough and blowing white smoke. i need so me advice please help
Old Mar 21, 2013 | 04:10 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 1996 ex with d16z6 swap
Get a set of feeler gauges and check them yourself.
Old Mar 21, 2013 | 05:35 AM
JuggerNaut-CTR's Avatar
x2 on checking yourself...
Is the "ticking" actually being heard in the head?
Just because valve lash is adjusted to spec doesnt mean there isnt other rocker/lma problems going on....just a thought.
Blowing white smoke is typically a sign of burning coolant....does the car over heat? Is the motor consuming coolant?
Old Mar 21, 2013 | 10:48 AM
Joe Hall's Avatar
No car doesnt overheat at all but i checked them and they have intake at. 007 and ehaust at. 009 is that correct. Also forgot to mention it is turboed. But turbo seems to be spooling fine and no shaft play.
Old Mar 21, 2013 | 10:50 AM
Joe Hall's Avatar
I am buying a test kit today to see if the head gasket is blown and doing a compression test to check if my rings are bad.but they shouldnt be car ran fine till i got the valves adjusted.
Old Mar 21, 2013 | 11:50 AM
Sounds like they adjusted them wrong then....
Intake = .007-.009
Exhaust = .009-.011
Give a little info on how you are checking the clearances...
honda_hackett
Sep 15, 2009 06:04 AM
oranginal
Jul 1, 2009 05:29 AM
KillerElfboy
Jun 18, 2006 12:23 AM
homesauce
May 26, 2006 11:51 AM
civicdude16
Jul 19, 2005 09:01 PM
