need help completing my b20b swap
Old Mar 20, 2013 | 07:19 PM
mando617's Avatar
Icon2 need help completing my b20b swap
so i have a b20b thats missing the throttle body, alternator, and distributor.
im also missing the ecu and harness(if i need one) and a couple mounts
i also got a gsr tranny to go with it
im throwing this into a 93 eg sedan that currently has a d15 in it at the moment
just trying to figure out what the best ecu dizzy and alternator for me to use are also im not sure if its obd1 or obd2 and what changes i need to make to the harnes
any help?
Old Mar 20, 2013 | 07:21 PM
mando617's Avatar
Default Re: need help completing my b20b swap
also first day on here
Old Mar 20, 2013 | 07:23 PM
Emeraldbomber's Avatar
p30 ecu, What year of crv did the motor come out of?
Edit: Sorry not the p30 a p75. Was thinking b16
B_Swapped93's Avatar
Best dizzy,ecu,alternator.....the one(s) that were meant for you'r engine are you going B20v as that will affect the dizzy and ecu
Old Mar 20, 2013 | 07:43 PM
mando617's Avatar
from what i was told its one from a 99 the one with the higher compression
i also read somewhere that the p75 ecu worked well with this engine toughts?
i was told it is from a 99-2001 so im pretty sure its a obd2 but just want to make sure
Old Mar 20, 2013 | 07:44 PM
Yes its obd2 then
you'r obd2 yes as for the question in you'r OP are you going B20V that will change what dizzy you will need/have and what ECU is best
Old Mar 20, 2013 | 07:52 PM
mando617's Avatar
its nota a b20v its a b20b
Old Mar 20, 2013 | 07:53 PM
mando617's Avatar
Yes its obd2 then
so what would i need to do with my harness buy a obd2 to obd1 converter thing ? would i need to extend any cables?
Old Mar 20, 2013 | 07:55 PM
alicuben's Avatar
Come on, you can do better.
I KNOW i was asking if in the future you were planning on going b20 VTEC b20 block with a b16 head....
Old Mar 21, 2013 | 02:47 AM
slowDB7's Avatar
get a converter harness for the distributor and fuel injectors, and get distributor for a 99 crv cuz that is what you said it came from
use your alternator from the d15
chip your current ecu to p75 maps or buy a p75 ecu
you shouldnt need to make any change to the harness if you get those harness converters above.
and get some aftermart b swap mounts like hasport or innovative
Old Mar 21, 2013 | 04:50 AM
mando617's Avatar
haha sorry i had no idea thats what a b20 vtec was called but no not anytime soon
Old Mar 21, 2013 | 04:54 AM
mando617's Avatar
awesome exactly what i needed
those damn mounts are gonna run my budget up a bit but i think it will be worth it
what do you guys think of the swap a good choice for my eg?
Old Mar 21, 2013 | 05:02 AM
mando617's Avatar
also what do you guys think of a gsr throttle body worth it or should i buy a regular one and wait till i can buy an aftermarket one
Old Mar 21, 2013 | 05:13 AM
mando617's Avatar
ok i found the harness converter for the distributor on ebay
http://www.ebay.com/itm/MSD-Ignition-8864-Honda-Acura-OBD-to-OBD-2-Distributor-Adapter-/200721764516?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ebbf310a4&vxp=mtr
but i couldnt find the one for the fuel rail whenever i searched it it showed me ecu jumper harnes. is that what i need? or am i just not finding the right one?
Old Mar 21, 2013 | 05:25 AM
slowDB7's Avatar
http://www.rywire.com/catalog/obd1-h...ters-p-36.html --- fuel injector converters, they have the distributor one too.
http://www.rywire.com/catalog/obd1-t...pter-p-42.html
id say just get a stock throttle body for now, and the mounts would definitely be worth it.
you will have lots of fun with this swap in your eg (:
Old Mar 21, 2013 | 05:26 AM
HondaPartsHero's Avatar
Technical Hero
You have a few options but that would be the easiest or get a 92-95 Integra LS distributor will plug and play. For the alternator you can use a 92-95 LS or if the engine came with one you can convert the plug over or use an adapter harness for that. You can use your injectors from the D15 as they are the same 240CC as the B20. Use your wiring harness for the rest.
Old Mar 21, 2013 | 05:30 AM
slowDB7's Avatar
i was gonna suggest the 92-95 ls dizzy too but didnt know if it would fit
Old Mar 21, 2013 | 05:58 AM
NVturbo's Avatar
O.G. triple O.G.
Yes it will. Just have to changeover the connector plugs. OP can run OBD2 engine harness with OBD1 P75 ECU. However, it seems like he just have a bare long block with GSR tranny and nothing much else.
Old Mar 21, 2013 | 08:08 AM
Technical Hero
The ls distributor would plug and play in his car as long as it was 92-95.
Old Mar 21, 2013 | 10:01 AM
You should have lots of fun with the B20 in the eg.
Old Mar 21, 2013 | 11:59 AM
mando617's Avatar
so for the injectors just switch over the whole fuel assembly the b20b already has the injectors and everything
Old Mar 21, 2013 | 12:09 PM
Then dont change anything?
Old Mar 21, 2013 | 12:37 PM
mando617's Avatar
what do you mean? lol
i probably should have mentioned that i have the obd2 harness (not the part that goes from the ecu to the rest of the harness). does that change anything or should i stick to the obd1 harness
jacx
16
May 28, 2014 10:08 AM
Mohsin Univrsal
Apr 10, 2014 01:09 PM
GT500FTW
Nov 5, 2012 09:57 AM
jdmborn
Engine Management and Tuning
Jun 20, 2009 08:15 AM
dliz88
Apr 22, 2009 04:58 PM
