VTEC issues
Old Mar 20, 2013 | 05:31 PM
petey1983's Avatar
Icon2 VTEC issues
I have a 95 Civic 2 door coupe. i am a first time honda owner. have a couple friends who are fairly knowledgeable with hondas though. It had a PO6 when i first bought it and a non vtec wiring harness. the engine is a D16z6 bottom end with a y8 head and a TD-42u distributor. we wired the vtec accordingly and i put a P28 in. the car does run better and stronger with the new ECU but it doesnt seem that my VTEC is working. Any help would be appreciated. Thanks in advance
Old Mar 20, 2013 | 05:33 PM
grumblemarc's Avatar
The Grumpiest
Default Re: VTEC issues
What do you mean "seems"? It works or it doesn't. Can you take it to redline. DO you throw a CEL when VTEC is supposed to kick in?
Old Mar 20, 2013 | 05:38 PM
petey1983's Avatar
Yes I can take it to the redline. And no there are no codes. The ECU I have came out of an automatic I have a 5 speed. The only codes are for the parking lock which is code 19 and for the o2 sensor which is 41
Old Mar 20, 2013 | 05:39 PM
crazyhouse2011's Avatar
Take it on a back road, get it into second gear at regular driving speed (i.e. 15-20 mph at approx. 3000 rpm, idk). Then mash the pedal to the floor. Listen for the engine to get louder, and feel for a sort of stronger pull (although these are SOHC VTECs, they don't seem to pull as hard without that exhaust VTEC that the DOHCs have). Then come back here and give us a heads up of what's going on. A video might be helpful too if you can manage it.
Old Mar 20, 2013 | 05:40 PM
The Grumpiest
Then it works.
Old Mar 20, 2013 | 05:42 PM
petey1983's Avatar
Can I upload a video here? And no that doesn't happen. I have tried that already. At te higher RPM it throws smoke and backfires when I shift
Old Mar 20, 2013 | 05:46 PM
stevenr2894's Avatar
Houston we have a problem
Old Mar 20, 2013 | 05:48 PM
The Grumpiest
Put the correct ECU in the car.
Old Mar 20, 2013 | 05:49 PM
petey1983's Avatar
What would be the correct ECU?
Old Mar 20, 2013 | 05:50 PM
renzis00's Avatar
borrow a multimeter from one of your friends. download a service manual. open with PDF, go to Section 6: Cylinder Head/Valve Train, go to page 6-3, troubleshoot.
Old Mar 20, 2013 | 05:52 PM
The Grumpiest
a y8 head
Old Mar 20, 2013 | 05:54 PM
renzis00's Avatar
^eh?! yeah get the right ecu. lol
Old Mar 20, 2013 | 05:58 PM
The Grumpiest
P28 or P2P.
Old Mar 20, 2013 | 06:00 PM
petey1983's Avatar
P28 is what I have.
Old Mar 20, 2013 | 06:03 PM
The Grumpiest
P28 for a MANUAL!! You said yourself the one you have is for an automatic and you are 5-speeding it now.
Old Mar 20, 2013 | 06:04 PM
petey1983's Avatar
I didn't think it would make that much of a difference. But I will def try that thank you
Old Mar 20, 2013 | 06:07 PM
That would be wise. Auto ecu in a manual don't mix
Old Mar 20, 2013 | 06:09 PM
The Grumpiest
It won't do anything for VTEC. It's working.
Old Mar 20, 2013 | 06:30 PM
+1
Old Mar 21, 2013 | 02:51 PM
xile6's Avatar
No clue for vtec and redlining normally means ots working.
But to fix your auto lockup code desolder the resistor in the ecu. I think its r18 and r17 needs a jumper. I dont remember its been a while.
And second pop the valve cover off and look toake sure all bolts are there.
I had the vtec bolt come lose and oil wasnt locking the rockers.
Also understand vtec on a d16 isnt the same as a b16 or b18.
MyEGisBad
Aug 12, 2010 08:07 PM
dougk1401
Dec 7, 2009 08:55 AM
stevil_knevil
Oct 26, 2008 04:55 PM
EKhothatch
Sep 2, 2005 09:08 AM
B18C-Hatch
Aug 31, 2002 02:04 PM
