Ignitor or coil problems?
Old Oct 22, 2002 | 07:32 AM
Amadeus's Avatar
Default Ignitor or coil problems?
I have a 92 SI with 252,000 miles. Over the past 2 years, the car has just died while driving normally and won't start again. If you let it sit a while, 30 minutes or more, it will fire up again.
Happened again yesterday, towed it to the Honda dealer because I thought for sure it was the coil or ignitor, well, started up again with no problems.
Any thoughts?
Old Oct 27, 2002 | 01:18 AM
ion_four's Avatar
Default Re: Ignitor or coil problems? (Amadeus)
hey dude...I'm having some ignition probs with me 93 Civic EX...I understand that would be the ignitor, since it works fine after cooling off...is yours the OKI (or whatever VS. NEC ignitor)? Whatever the other one is besides the NEC is supposed to be crap. A Honda Master Technician told me these tidbits (thought they didn't help my situation )
here's my deal... https://honda-tech.com/zerothread?id=317619
good luck
Old Oct 27, 2002 | 07:56 AM
BoostedH23a1's Avatar
Default Re: Ignitor or coil problems? (ion_four)
all u have to do is get a friend. now while he trys to start the car u take a plug wire off and have it about 1/2 inch away from a grouned bolt (header bolt or something). if u see a spark jump then its not your ignition. to check the coil unplug the coil wire from the dist. and do the same thing.
Old Oct 27, 2002 | 07:36 PM
Turbo Lude SH's Avatar
Default Re: Ignitor or coil problems? (BoostedH23a1)
But friends are so hard to get.
[Modified by Turbo Lude SH, 8:36 PM 10/27/2002]
[Modified by Turbo Lude SH, 8:37 PM 10/27/2002]
Old Oct 27, 2002 | 07:38 PM
PrecisionH23a's Avatar
Default Re: Ignitor or coil problems? (Turbo Lude SH)
Let me know if you need a stock coil, i have 2 OEM honda coils in perfect condition.
bk7794
Nov 13, 2012 08:38 PM
jsharpe
Aug 6, 2007 01:15 PM
Stealthman80
Jul 24, 2007 05:39 PM
astig1510
Apr 13, 2007 04:26 AM
