ecu help
Old Mar 20, 2013 | 03:29 PM
gabriel0830's Avatar
Default ecu help
i drive a 94 honda civic sedan automatic tranny
i swappd the motor to a D16z6 vtec, also i had to change my P06 ecu to a P28 so i was told, so i got one but once installd my car took a while to turn on and also it did nt let me switch gears
so i thought it was tranny but i switchd my ecu back to the P06 and it was shifting good! so i want to know what the heck is up wit the ecu they told me to change ot because my car kept on turning off when i was stopped completely even on drive. it would also take a reallyy long time to turn on
can someone tell me how to make this ecu work please or something
Old Mar 20, 2013 | 03:51 PM
B_Swapped93's Avatar
Default Re: ecu help
It's got to do with the fact that the p28 is from a manual car. sort of like a GS-R ecu would not work to well/if at all with an auto LS. (Correct me if im wrong but that's my theory)
Old Mar 20, 2013 | 04:11 PM
is it? i was told it would work
Old Mar 20, 2013 | 04:14 PM
Basik_One's Avatar
You need an auto p28
Old Mar 20, 2013 | 04:18 PM
Old Mar 20, 2013 | 04:55 PM
it is an auto one at least thas wat theyy told me
Old Mar 20, 2013 | 05:16 PM
grumblemarc's Avatar
The Grumpiest
"They"? How about find out for sure? What are the numbers on the side of the ECU?
Old Mar 20, 2013 | 05:23 PM
petey1983's Avatar
i am also having a problem.. i am a first time honda owner i have a 95 2 civic 2 door coupe has a d16z6 bottom end with a y8 head had a p06 in it when i initially got it. non vtec wiring harness. i bought a P28 ecu and wired up the vtec accordingly. but it still doesnt seem to be working. is there anything i could have missed? please help. thank you in advance
Old Mar 20, 2013 | 05:24 PM
petey1983's Avatar
also has a TD-42u distributor
The Grumpiest
Start your own thread. This issue isn't even related.
Old Mar 20, 2013 | 06:03 PM
37820-P28-A52761-778106 AWN
Old Mar 20, 2013 | 06:05 PM
The Grumpiest
Sounds like an automatic. But I only took 5 seconds to search.
Old Mar 20, 2013 | 06:09 PM
i checked it too and confirmed its an automatic but i aint got no clue when i installed it the cel came on i pulled the code it was 13 i believe and it said exhaust something also i would have to push the gas to start it
The Grumpiest
Can you verify that code?
Old Mar 20, 2013 | 06:13 PM
92-5 ECUs (P28, P30, P61, P72, P91, P08)
5spd = 000, 001, 002, 003, A00, A01, A02, C00, C01, C02, J00, J01, J02
Auto = J50, J51, 901, 902, C50, C51, C52, A50, A51, A52
off a honda tech forum
Old Mar 20, 2013 | 06:30 PM
welll you have an auto ecu... look after the p28 it says A52 listed under the auto ones
Old Mar 20, 2013 | 06:32 PM
ya i know its wierd my friend is tellin me it could be my distributor
Old Mar 20, 2013 | 06:33 PM
can you get hold of another p28 auto there's always a chance your's has an issue
Old Mar 20, 2013 | 07:03 PM
Emeraldbomber's Avatar
Your friend told you you cant change gears and your throwing an exhaust cel because of the distributor?
Maybe you should stop listening to him
Old Mar 20, 2013 | 07:53 PM
its not the ecu we tried it on my brothers 95 ex nd it worked good
Old Mar 20, 2013 | 07:59 PM
jbpnoman's Avatar
Pull the CEL codes again for verification. Post all of them.
Old Mar 21, 2013 | 03:16 AM
The Grumpiest
No. The CEL code.
Old Mar 21, 2013 | 08:32 PM
P28 CEL Code
P06 CEL Code
Alcura321
Mar 29, 2015 07:20 PM
eg6king!!!
Jan 27, 2012 05:59 AM
hondakid09
Jan 16, 2010 11:55 PM
Nino_eg6
11
Jun 17, 2008 07:26 PM
