97 civic
Old Mar 19, 2013 | 04:53 PM
Screws71's Avatar
Default 97 civic
I have a 97 civic cranks but no start.. 40 psi fuel pressure 150 lbs compression and spark all 4cylinders.. Can anyone help
Old Mar 19, 2013 | 06:04 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 97 civic
Spark?
Old Mar 20, 2013 | 12:00 PM
Screws71's Avatar
Yep has spark... Just can't figure it out
Old Mar 20, 2013 | 12:13 PM
The Grumpiest
What color is the spark? Are you getting fuel to the injectors?
Old Mar 20, 2013 | 03:21 PM
Screws71's Avatar
spark is blue can get it to jump an inch from lpug to manifold.... fuel to injectors,have pulse at injectors, checked with my noid light
Old Mar 20, 2013 | 04:17 PM
motoxracer98's Avatar
check engine light on ? could be a crank sensor
Old Mar 20, 2013 | 04:40 PM
Screws71's Avatar
No codes pending or in history... Gotta be something stupid
Old Mar 24, 2013 | 02:02 PM
wwcrxww's Avatar
Is your fuel pressure consistant? meaning when you crank it over does it hold that pressure? or does the pressure drop? also where are you checking for fuel pressure? on the rail, the filter? you can have 40 pounds of fuel all day but wont do any good if you dont have the volume you need....a plugged fuel filter, a weak fuel pump, a collapsed fuel hose, a faulty pressure regulator can all play a role in fuel volume. you want to check the pressure at the fuel rail preferably closer to the regulator...
just for kicks pinch off the fuel return hose on the right side of the fuel rail and give it a try..this may help if it is actually starving for fuel
if you have access to one, try a different computer. even though you have spark fuel and compression - there can still be an issue with the ECU..you have injector pulse so the ECU is definitely getting power.
inspect all of the connector pins for anything that may be loose, bent, or dirty
Double check your ignition wires..make sure they're going to the correct cylinder
lastly clean all of your grounds - take them off clean them and reconnect them, its the most simple and very common issue- a dirty ground will cause poor communication between all the sensors and can also fluctuate the voltage throughout the system...its worth a shot!
good luck!
Old Mar 24, 2013 | 11:39 PM
Spoonlin's Avatar
ecu fuse, check that out also
Murk 'EM
Oct 6, 2007 08:04 PM
jman86
Aug 26, 2006 08:13 AM
Islander
May 19, 2003 11:08 AM
