someone explain this to mee pleasee
ok i always have my SRS light on i tried reseting it using the paper clip method the process goes very well until the end when it blinks twice and its supposed to turn off it blinks twice but twitches and stays on so i gave up but after my swap, my check engine came on it would go off and on when it wants to. so i recently tried pulling the code, but when i did the check engine light stayed on no blinks so i assumed its my ECU but than the srs started blinking watch the video it shows the process and someone explain to me what the heck it means
i currently own a 94 civic sedan, i swapped the stock d15 to a ZC vtec engine my current ECU is P06 they told me to swap to a P28 is it true?
ZC VTEC is similar to the D16Z6 motor. A P28 ecu is what you need. The CEL light is coming on because you are running the WRONG ECU. I'm assuming you wired in the VTEC wiring to the ECU, correct?
ImportPower13
26
Mar 3, 2005 03:31 PM
lilxvtecxpwr
Aug 9, 2002 09:14 AM
