d16y7 problems
Old Mar 18, 2013 | 12:21 AM
R.sok's Avatar
Default d16y7 problems
So my friend bought a motor, installed it & upon starting it, it was leaking oil "from what we thought was the front crankshaft seal" . Took it all apart, purchased a new oil pump & installed it only to find out it still leaks!
It is leaking from the front side of the oil pump in between the aluminum "not the crankshaft seal itself" What should I do? Can I just buy hondabond or any other rtv, put it on the oil pump & bolt it in that way?
Old Mar 18, 2013 | 03:57 AM
grumblemarc's Avatar
The Grumpiest
Default Re: d16y7 problems
How about make sure the seal is installed properly? That the surfaces smooth and free of any gouges or other deformity?
Old Mar 18, 2013 | 05:01 AM
slowDB7's Avatar
that could be why the last owner sold it
Old Mar 18, 2013 | 08:19 AM
sde780's Avatar
Is it leaking from the pump or oil pan? Did you use a thin layer of hondabond when installing the new pump?
Old Mar 18, 2013 | 12:46 PM
R.sok's Avatar
Crankshaft seal is installed correctly & Before installing, I cleaned all the surfaces. This is probably why the guy sold it. It is leaking from the left side of the oil pump Towards the bumper.
I didn't use any layer of sealant because I never had to, My question is would it be safe to use some to fix the problem
somick
Aug 15, 2017 08:14 AM
Corksil
Jan 25, 2011 10:36 AM
pjr710
Feb 24, 2009 07:05 PM
Tzarinque
Sep 19, 2008 09:59 PM
teler86
May 31, 2006 08:54 AM
