Honda CR-V & Element 2WD & 4WD Element & CR-V
Can have stagger rims on a 99 crv with the allwheel drive
Old Mar 17, 2013 | 08:02 PM
dpapichulo718's Avatar
Default Can have stagger rims on a 99 crv with the allwheel drive
wazup ppl i got a 99 crv and i was wondering if i go 18x9 and 18x10 would it affect the differential or the all wheel drive in any way possible
Old Mar 17, 2013 | 08:12 PM
Default Re: Can have stagger rims on a 99 crv with the allwheel drive
bumppppppppppp
Old Mar 18, 2013 | 09:40 AM
77777's Avatar
so much bad information on this out there, mostly from tire shops and such. with the simple mechanical system we have here i dont see how it would hurt you. worst case if you are paranoid just select tires that will have the same height or run square tires and you are good no matter what sort of 4wd vehicle you have. wheel sizes are irrelevant its tire size that can get you on certain 4wd systems.
i drove on my 350z's wheels for a minute, took them off because they looked like ****, but they ran just fine.
Old Mar 26, 2013 | 11:11 PM
newby_j's Avatar
Needs More Cowbell
You could always remove the driveshaft if you wanted to be sure
Old Mar 27, 2013 | 12:05 AM
LDForget's Avatar
Shouldn't be a problem as long as the diameter of the tires are the same. The problem you're going to have is wheel poke
junkit54
Jan 7, 2010 06:15 AM
cecknight
Jan 13, 2008 07:21 AM
PVD24
Jul 11, 2006 05:10 AM
bluebullet
Jan 5, 2006 11:29 AM
CrOmEdOmEcHaMbEr
16
Feb 27, 2002 03:46 PM
