gauge cluster on the fritz jdm eg6
Old Mar 16, 2013 | 09:50 AM
Freshdot's Avatar
Default gauge cluster on the fritz jdm eg6
So in the process of making my fully functioning properly jdm cluster into a usdm hybrid piece, I've apparently messed something up good. From the JDM cluster I removed all needles and gauges faces along with the odometer and replaced everything with USDM parts in order to have black faces that read in MPH with red needles. The job wasn't easy as these clusters are a lot more different than you would think. Either way I slapped everything together and now the only things functioning are the odometer, turn signals, and warning lights..none of the needles work..the rpm stays at 3k, the speedo at 40mph, and the temp pinned at full hot.
Old Mar 16, 2013 | 10:02 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: gauge cluster on the fritz jdm eg6
Should have never removed the needles. I have always had bad luck when I have. I am afraid you might be sol
Old Mar 16, 2013 | 12:09 PM
Freshdot's Avatar
I've removed needles in the past without issue, that's why this is driving me nuts.
Old Mar 16, 2013 | 12:13 PM
grumblemarc's Avatar
The Grumpiest
I was told to NEVER remove the needles. Maybe you lucked out before.
Old Mar 16, 2013 | 03:37 PM
Freshdot's Avatar
I've seen custom gauges by the **** ton, that can't be fact
Old Mar 16, 2013 | 03:43 PM
Freshdot's Avatar
For example, when I installed the srs light from the usdm to put in my jdm cluster the needles have to come out and the cluster functioned fine
cehcivic15
Nov 13, 2009 04:54 AM
DA KING
Oct 30, 2004 02:33 PM
AMG
16
Oct 15, 2002 10:22 PM
sk4sk4
Oct 9, 2002 03:23 PM
W0oT
Aug 5, 2002 12:56 PM
