gauge cluster on the fritz jdm eg6
So in the process of making my fully functioning properly jdm cluster into a usdm hybrid piece, I've apparently messed something up good. From the JDM cluster I removed all needles and gauges faces along with the odometer and replaced everything with USDM parts in order to have black faces that read in MPH with red needles. The job wasn't easy as these clusters are a lot more different than you would think. Either way I slapped everything together and now the only things functioning are the odometer, turn signals, and warning lights..none of the needles work..the rpm stays at 3k, the speedo at 40mph, and the temp pinned at full hot.
Re: gauge cluster on the fritz jdm eg6
For example, when I installed the srs light from the usdm to put in my jdm cluster the needles have to come out and the cluster functioned fine
DA KING
10-30-2004 02:33 PM
W0oT
08-05-2002 12:56 PM
