98' JDM ITR header
would that big of a header be too big for an I/H/C/E setup for an LS? and i might possible do cams or adj cam gears also. how much weight would i reduce with this header? if i use a ITR exhaust would i be restricting airflow??
your not gonna loose much weight if any. if you use the itr exhaust with it yes it would restrict air flow a bit since the header is 2.5'colector and the ITR exhaust is a bottlenecked 2.25'.
You guys actually recommend a 4-1 header with a 2.5" collector for a mildly modified LS?
BTW, it's about 10lbs. lighter than the OEM cast iron manifold.
My recommendation for a street-driven LS would be the Comptech 4-2-1, or maybe a DC 4-2-1.
I do not think that a 4-1 header with a large collector would be well-suited to the power delivery characteristics of the B18B. But if anybody cares to prove me wrong I'm all ears.
would it give better gains than a dc sport 4-1 header?
looks like u have lots to learn
4-2-1 or 4-1??
